Apexi SAFC
Old Jul 7, 2009 | 07:47 PM
mello1's Avatar
Question Apexi SAFC
Looking for advise on the subject. I just bought an evo7 and the previous owner had a SAFC installed. Can this cause any problems. The car is basically stock walbro pump and running 15psi low boost & 20 high K&N drop in, 3inch exhaust. What do you suggest I do leave it in or remove and tune the stock ecu. Can this cause any harm to the motor?
Old Jul 7, 2009 | 07:49 PM
FedEvo8's Avatar
Remove the SAFC and tune the stock ecu. I've heard the 8 ECU works?
Old Jul 8, 2009 | 11:28 AM
turbolarry's Avatar
If the settings are correct and it is tuned properly it should not hurt the motor. If things are running good, leave it in for now, until you make a decision on what you want to do.
If you really want to remove it double check and make sure the stock injectors are still in there. If they are, then it should be OK to remove the S-AFC and leave the boost low until it can be tuned.
Old Jul 9, 2009 | 07:35 PM
mello1's Avatar
Thumbs up
Thanks guys for your feedback. Anymore comments from anyone?
Old Aug 6, 2009 | 07:18 PM
vigilante.zen's Avatar
I would remove the SAFC. It doesnt do anything for the EVOs really... Sell it and get a tune you will be much happier. I had one in my car at one point in time and ended up selling it to a guy with a Lexus IS300.
dadsgts
Lancer Engine Management / Tuning Forums
Jul 7, 2013 09:54 PM
smokey
Mar 10, 2005 04:38 PM
tokeone
Jan 13, 2005 03:34 PM
ltwayner
11
Dec 28, 2004 01:35 PM
lynkz
Aug 24, 2003 09:27 PM
