How do these numbers look?
Old Aug 30, 2009 | 07:24 PM
evo unknown's Avatar
I recently installed a Cobb Acessport with the stage 2 map. Other mods are in my signature.
With the AP I can monitor engine knock sum, timing, etc. But, what numbers should I be looking for with knock sum and timing? I want to make sure I'm running good, but I have heard different range of numbers. And what would happen if the knock sum is greater than the normal values?
Also, if someone could give me a better definition of knock and timing I would appreciate it. I'm somewhat new to tuning.
Thanks in advance!!
Old Aug 30, 2009 | 08:03 PM
KenMasters's Avatar
Knock is detonation, Timing is when energy is sent to the spark aka ignition. Detonation is premature ignition or ignition from source other than the plug.
This is how I understand it. I am no engineer. It is worth a wiki.
Old Aug 30, 2009 | 08:13 PM
NeoGearX's Avatar
For Evo 8s <= 3 counts of knock is ok, ideally you want as much timing as possible without knock, but that's theory. In practice, with your logs, determine where the knock is happenening (what rpm range and timing and AFR values etc) and either decrease timing, encrease fuel mix (lower AFR) or both.
Knock can be attributed to many factors (ones listed above) and grade of fuel ... you can try keeping your current timing and AFR values and run higher octane fuel to reduce knock.
Old Aug 30, 2009 | 08:31 PM
ok thanks. I was told <=3 but also heard 7-8 is ok. I have hit up to 10 sometimes, but i will have to take notice of where those spikes occur.
Old Sep 8, 2009 | 03:21 PM
801bmx's Avatar
3 is normal anything over three with WOT is not good....
Old Dec 2, 2009 | 05:15 PM
darthvader's Avatar
More than 3 on the knock counter is a no no as far as timing you need a dyno to properly adjust just because you have no knock when advancing doesnt mean it is making more power -you could be just creating more heat and stress with no gains
hope this helps
Old Dec 22, 2009 | 11:45 AM
Motor-Rx's Avatar
Originally Posted by darthvader
..just because you have no knock when advancing doesnt mean it is making more power -you could be just creating more heat and stress with no gains
hope this helps
Good point.. Hmmm..
Old Jan 15, 2010 | 08:17 PM
evolvd276's Avatar
3 counts of knock is equal to one real knock because the EVO knock sensor is so sensitive.
Old Sep 22, 2010 | 08:58 PM
tuner83's Avatar
So how many knocks is needed for the ecu to trigger a knock retard? they go by number of knocks or the intensity of the engine noise detected?
Old Sep 23, 2010 | 10:18 AM
artisticspawn's Avatar
I have read by an old Evom Member who left the EVO scene a while back, that the Cobb AP can read up to 5 knock sum and it seems to be OK. I also have read others saying even up to 6/7 is OK therefore what evolvd276 said could be true; that our knock sensor is extremely sensitive. I have seen up to 3 and 4 knocks through my AP.
Old Feb 5, 2011 | 02:20 PM
MikeS54's Avatar
3 is the max you want
Live4Redline
Jul 17, 2024 07:09 AM
mrfred
39
May 18, 2011 05:05 PM
rodrig.diaz3
Jun 30, 2008 10:13 AM
rsboy
Dec 19, 2006 12:35 PM
