What dyno numbers should i expect with my setup??
Old May 17, 2011 | 05:55 PM
AWD96's Avatar
I just made 270whp 270wtq @ 23psi on STM's Mustang Dyno with Emery tuning it. I have an STM 3" Turbo back, STM Intake pipe kit, Hallman Pro, and a 255. You have an MR BOV which will hold more boost so you might hit close to 300whp on a Mustang or 550whp on a DynoJet haha. My car as it sits can trap 110-112 depending on how Ricky Bobby I get with it.
Stock Evo injectors should be fine all the way up to about 350 MD whp, Unless you want to run E85 then go 1000cc or 1050's and really make it rip.
Old May 17, 2011 | 09:32 PM
Nelson999's Avatar
aight thanks for the info man, id love to go e85 but theres only one place to get it that i know of within 20 miles from my home and work so idk if i want to.
im assuming that since u were talking about trap speed u have raced it? so what did you run on the 1/4 mile with the 270WHP setup u mentioned
Old May 17, 2011 | 09:33 PM
Nelson999's Avatar
Originally Posted by fugiwara
I had about the same setup as you when I first got tuned (05mr).
I strongly suggest you get cams then a tune. Cams makes so much difference on our evo8 engine, because evo 8 has weaker intake cams compare to evo 9.
In the future if you want more, then do the turbo.
Listen to my advice and you won't regret it.
whats the best cams to go with?
and if i did add cams before the tune what dyno numbers would i be looking at?
Old May 25, 2011 | 12:45 AM
AWD96's Avatar
http://www.youtube.com/watch?v=efSQMTZajgw
This is my friend Yaser's Evo that made the same power as mine with the same mods, he got a best of a 12.30@110. I just had an Exedy Twin HD installed into my car at STM today, and the Buschur Sport Compact event is this weekend so I might see what I can do with her.
Old May 25, 2011 | 02:24 AM
jameswwt's Avatar
Then how about mine?
-PFC ecu
-GSC S2 cams
-GT3076R A/R60 / 0.63
-Walbro 255
-Tomei Fpr
-600x300x70mm I/C
-BC valvesprings + retainers
-GSC lifters
-Pump gas
Boosting on 1.5 bar?
What's the estimate whp and torque on my set-up? (Im from a tropical country)
Old May 25, 2011 | 10:22 AM
walker992's Avatar
i would recomend higher injectors if u plan on turning up the bosst sand producing more power that way u dont max our ur stock injetors
rdtech
Dec 31, 2014 07:08 AM
stunna2o1
May 21, 2014 09:37 AM
EvolutionXmr
Oct 19, 2011 09:15 PM
PERRIN_JOHN
24
Apr 23, 2009 11:01 AM
skags
11
Aug 23, 2007 02:42 AM
