Help W/ E85
Old Sep 6, 2012 | 06:13 AM
YuLost2x's Avatar
Help W/ E85
So I think I want to go E85 on my current setup. I'm running a Buschur FS635 with supporting modds on 93 pump. I want to do E85 and was wondering how big of injectors I would need (current FIC 1050cc) and currently on just 1 Walbro 255. I was thinking of ordering the Walbro 450 LPH (http://www.streettunedmotorsports.co..._f90000267.htm).
what injectors do you guys think I should go with to be safe?
Old Sep 6, 2012 | 06:58 AM
boosted91t's Avatar
If you are going to be using pump gas occasionally, I am a big fan of the FIC Bluemax 1250 and 1450 at that power level specifically because they are manageable on pump gas.
The wally 450 is a nice pump. I recenlty opted to pull mine out and build a double pumper tho. Base pressure was easier to maintain with the double, even with a fuelab fpr.
Old Sep 6, 2012 | 08:16 AM
YuLost2x's Avatar
Only time I would be using pump gas would be just to clean out the injectors from the E85.
Old Sep 9, 2012 | 08:25 PM
YuLost2x's Avatar
anyone else? any other input or anything?
Old Oct 2, 2012 | 04:42 AM
siemens03's Avatar
You can always scale down a big injector if needed but you can not make a small injector bigger. Get the big 1650 high z's and be done with it.
Old Oct 2, 2012 | 12:57 PM
CDrinkH2O's Avatar
I'm running the FIC1050's with a Walbro 400 on E85 and 91 and they work great. No need to spend any more money to upgrade unless you are built and want more than 475WHP/450WTQ
Old Oct 3, 2012 | 04:34 PM
siemens03's Avatar
All im saying is if your going to purchase new ones for whatever reason buy the good big ones and be done with it. never buy another set.
Randal
Aug 20, 2013 07:12 PM
YuLost2x
E85 / Ethanol
Sep 13, 2012 12:25 PM
JC evo1
14
Apr 30, 2011 11:36 PM
Sacevo9mr
Mar 21, 2011 11:06 PM
Dannievo
16
Oct 6, 2010 08:16 PM
