Boost cut
Old Feb 18, 2013 | 12:10 AM
fsc0224's Avatar
Boost cut
I have a 05 evo. I have the AEM electronic boost controller. And evo 9 FP green turbo and stock 550 injector, and running 91 gas. I have a problem with the boost recently. It is like when I raise it up around 21 or 22 psi, there was a boost cut so bad. And when I turn it to 20, that won't happen. When I did it, the weather was like 14 degree. I wonder is that max up my injectors or sth else?
Old Feb 18, 2013 | 01:33 AM
tscompusa's Avatar
you either need to raise your boost cut load % or gap the plugs tighter or get new plugs. its probably just the boost cut though if it has no tune on it.
Old Feb 18, 2013 | 12:43 PM
fsc0224's Avatar
Thx man. I ll order the plug asap and see what will be doing
Old Feb 19, 2013 | 01:07 AM
tscompusa's Avatar
no problem.
isnake
Apr 9, 2017 02:01 AM
vteckiller
21
Apr 16, 2015 07:58 AM
peisden
Apr 12, 2015 03:29 AM
101516
29
May 4, 2014 05:28 PM
Kyleboyd03
E85 / Ethanol
17
Oct 11, 2013 09:53 AM
