How does ecutek work?
Old Mar 11, 2013 | 08:05 AM
Driv200's Avatar
Just had tuner install on car. Said he lowered duty cycle to 30%. It sounds like a pulsing/fluttering sound when on boost. I am not clear on what ecutek is doing or how it is working. Can someone help me understand. I am an idiot when it comes to mechanics.
Old Mar 11, 2013 | 11:24 AM
Driv200's Avatar
Rephrase question: I know it's software, but what is the fluttering or pulsing sound coming from wastegate or blowoff valve I now hear? Tuner was trying to reduce boost through Ecutek.
Thanks.
Old Mar 19, 2013 | 10:09 AM
Biskitz's Avatar
Sounds like you may have a faulty blow off valve. I'm no expert but I know that Without a BOV, the pressurised air being pumped into the engine by the turbo will have only one path when the throttle is closed: back through the turbo compressor. The fluttering sound is the sound of this air against the blades of the spinning turbo compressor as it tries to flow through it the wrong way. You obviously have a BOV. But it may be faulty. As I said, i'm no expert, so if I were you I would take it to your local tuner and have it checked out ASAP.
Old Apr 9, 2013 | 07:38 PM
Driv200's Avatar
Update: I was incorrect. It's on EcuFlash & 3 port boost controller.
Old Apr 14, 2013 | 08:37 AM
evo8426's Avatar
The clicking noise is the 3 port opening/closing which is nothing to worry about.
trinibt65
Nov 17, 2017 10:07 PM
testerix
Jun 20, 2016 05:44 AM
Jonno99
Mar 10, 2016 12:46 PM
Jonno99
Jul 3, 2015 09:03 AM
ErroR
38
Jun 15, 2006 02:29 PM
