switching between maps on tephra7?
Old Apr 29, 2014 | 02:25 PM
slowsrt4:('s Avatar
Hello, do you have to buy some type of switch to switch between maps on tephramods V7? I was going to say I remember hearing that you could do something like push in the clutch pedal a certain number of times in a certain configuration in order to activate an alternate map? any insights would help, i have seen older versions of the tephramod where you had to have a physical switch wired to your ecu using resistors and things in order to switch between maps.
-Sean
Old Apr 29, 2014 | 02:38 PM
e_kobz's Avatar
You put the key in the ignition and turn it one click so the battery comes on and you hold down the gas pedal for 4 to 5 seconds.
Old Apr 29, 2014 | 02:47 PM
slowsrt4:('s Avatar
thanks man, I knew there was an easier way to do this, how can you tell which map you are on though (will be doing an e85 map and a 93 map)
Old Apr 29, 2014 | 02:56 PM
mdsevo06's Avatar
Your tunner will let you know which is set for, and there should be enough difference between the two.
e_kobz's Avatar
Its kind of up to you to remember what fuel you put in your car on your last fill up. I switch between a 91 and E85 map.
Old Jul 27, 2014 | 05:38 PM
slowsrt4:('s Avatar
nice, thanks guys!
tephra
Apr 22, 2026 11:03 AM
RoadSpike
Apr 10, 2023 02:19 AM
clockworktoy
Dec 11, 2011 12:20 AM
newpassport
Jul 3, 2011 07:30 AM
wtf_is_a_evo
May 18, 2009 07:40 PM
