Knock Sum stuck at 0 or 9
Old Jul 22, 2014 | 10:10 PM
URNVS's Avatar
Hi, Im seeing some unusual behavior from my Evo 8 while tuning. The Knock sum (count) indicator will stay at 0 until I hit boost, then it goes straight to 9 where it remains pretty much no matter what is done to boost level, timing etc.
Should I be looking at the sensor, or can something else cause this?
Old Jul 23, 2014 | 05:14 AM
wreckleford's Avatar
Your knock sensor is bad or disconnected. The straight 9 knock counts is almost like a CEL for the knock sensor. Your car will also automatically default to the low octane map. You should get a knock sensor cel sooner or later.
Old Jul 23, 2014 | 06:06 AM
charlie.tunah's Avatar
X2. Mine did the same when forgetting to plug it back in after a bunch of work to the car. Had me freaked out for a minute.
Old Jul 23, 2014 | 02:34 PM
URNVS's Avatar
I think I will have to redact my initial parameters :P
I get 0 knock at idle, its gone as high as 36 during pulls, but it always stays at 9 at WOT.
jcsbanks
Sep 19, 2009 01:34 PM
tk2481
Mar 27, 2008 05:08 PM
06 SLOW EVO
Aug 6, 2007 09:35 AM
vroomevo
Apr 27, 2007 12:44 PM
ant_turbo
Sep 25, 2006 03:08 PM
