new evo8 owner with CEL flashing
Old Aug 21, 2014 | 08:13 PM
byeai's Avatar
Hey guys I got a evo8 the other day was driving and noticed the check engine light flashing connected the obd2 scanner to it no codes found so tonight I was on way home and was messing around with it and if I slowly get into boost and then punch it and its fine boost perfect and no check engine light then I was like ok but if im at 2500 rpm or 3000 rpm and give it decent amount of gas and bam check engine light flashes yes ive read around and people say knock sensor but wouldnt it pop on no matter what even at full boost if thats what it was but if I baby it get into 5psi and punch it it fully boost and easily gets to rev limiter and I can keep shifting through all gear and no l8ght
Old Aug 21, 2014 | 08:51 PM
badhabit90's Avatar
knock , knock....??
Old Aug 25, 2014 | 08:31 PM
boostin4kix's Avatar
You should check to see what rom is in the car. The tephra roms have a "Flashing CEL on Knock" feature. If this is the case, then your check engine light will flash whenever a certain amount of knock occurs after a certain amount of engine load. You may want to get your car tuned if your engine is knocking/detonating.
740 Turbo Brick
Oct 21, 2015 05:32 PM
byeai
Aug 25, 2014 09:29 PM
sgambino92
Jul 31, 2014 09:28 PM
GTR2009
Jun 7, 2010 07:13 PM
tomatoEVO
Sep 2, 2008 07:31 AM
