I can't log with an eee pc running XP using Evoscan
Old Oct 27, 2015 | 03:57 PM
EvoOtto's Avatar
I have an 09 Ralliart and had been able to log with it before but now I'm having a problem. I remember 2.7 working for me but the newer versions never working. Now I can't log with any version. Ecuflash works fine so I don't think it's the cable. Any help would be appreciated.
Old Oct 27, 2015 | 04:52 PM
wheatbix's Avatar
Can you just go back to the older version? Or re-install the software, I found this reinstalls the drivers for the cable (provided the cable is plugged in at the time of installation).
You can always contact Evoscan directly too, Hamish (the guy who owns the business) has always been super helpful to me in the past.
Old Oct 27, 2015 | 05:36 PM
EvoOtto's Avatar
I could try reinstalling all three. 2.7 2.8 and 2.9. Hopefully one of them will work. Are drivers deleted when programs are deleted? Either way I will give it a shot and post back thanks.
Old Oct 27, 2015 | 05:49 PM
kaj's Avatar
kaj
did you go in and re-select the COM port? i had to do that each time i upgraded. other than that, be sure you have the right box checked for your cable (1.3 or 2.0) and that the other settings are correct (CAN BUS blah blah up in the top, right hand corner).
worse comes to worse, you can go to BoostedTuning.com. i think he has the older version listed on his site. if not, PM him here and i'm sure he can help.
good luck!
Old Oct 27, 2015 | 07:12 PM
hearnoevo's Avatar
evo
Evoscan website has 2.5 to 2.9 available to download. They also have Ecuflash 1.43 and 1.44.
Old Oct 29, 2015 | 02:05 PM
EvoOtto's Avatar
I reinstalled the drivers for Evoscan and now can read parameters which I couldn't before but only selecting ECU: EVOX CAN MUTIII. Not sure what I need to do to fix this. I'm using an eeepc running Windows XP. Any help would be appreciated. Thanks.
stokEd
16
Nov 26, 2025 01:12 AM
Jim in Tucson
Feb 12, 2008 06:26 PM
EVO8LTW
Feb 6, 2008 09:20 PM
UndieStainz
AEM EMS
16
Sep 28, 2006 03:50 AM
