Need a good tuner
Old Jun 17, 2017, 02:10 PM
Abacus's Avatar
Originally Posted by Pal215
A 2.3 liter has a recommended limitation on rpm, not whp. It also has more to do with which internals you go with.
The big crank has alot more going on then a smaller crank. I'd limit it to a clean 700whp or less.
To the OP, I'd go with a well known E tuner OR preferably put it on a dyno on low smoothing and get it tuned. You can see alot more in a dyno session then barreling down the road for hours on end relying on hobbiest software and a single knock sensor.
Of course before you go develop a checklist and get the car ready to tune.
Old Jun 21, 2017, 04:03 AM
tscompusa's Avatar
No need to limit a displacement to a certain power number assuming other vital criterias are met. The last 2.3 full build we did at the shop made 840WHP+. More displacement makes power easier with less boost due to its more efficiently done.
There's far to many variables, but in reality a 2.0 will be more reliable and last longer than a 2.0, but that's only if everything's done properly. I tune built 2.0's by other shops who have more vibration in the rotating assembly than some of our 2.3's due to balancing and assembly in general.
Heres a very old but good article regarding strokers: http://www.speedperf6rmanc3.com/content/StrokeOrNot.pdf
In regards to tuning, street and dyno work well. It comes down to the tuners ability more than anything. A lot of dyno owners start the tune on the street still.
Pretty sure i got your MHI Red record beat also from a customer from 2012.
Old Jun 28, 2017, 03:52 PM
Pal215's Avatar
Excellent article Tom! Will be reading through this one for sure.
Old Jul 1, 2017, 06:58 AM
Cogito's Avatar
Have you considered D3PE in Houston? They seem to have a good handle on the ProEFI system for multiple vehicle types.
Evo8RA
Feb 13, 2006 10:27 PM
Evo8RA
Jan 28, 2006 12:38 PM
LEVIII
Jun 27, 2005 09:20 AM
Robdevo
Feb 26, 2005 07:13 AM
Quick Reply: Need a good tuner
