Can I tune away this problem?
Old Jul 17, 2020 | 10:34 AM
Biggiesacks's Avatar
Originally Posted by Evo8cy
Scavenging does not apply on the specific case, gasses or oxygen from the leak are not drawn from, they are forced frontwards/outwards. Scavenging would apply much later down the pipeline of the exhaust system. But still even if there is oxygen drawn into the pipe by a leaking gasket it will not affect the o2. You can actually try it if you want actual first hand evidence. Just loosen up the bolts of your o2 housing a bit so that a thin piece of paper can be squeezed in there and then start the car. You will notice no difference in idle. You can also do the same by removing one pipe of the sas system i.e on the exhaust manifold, or the bolt if you have removed the system, you will also notice no change in idle, but you will notice the extra sound frequency and pitch.
Marios
Thanks for you input Marios, I appreciate having my assumptions challenged.
Old Jul 17, 2020 | 10:46 AM
Evo8cy's Avatar
No worries on that but I haven't challenged anything, I merely stated facts. Well if you wish to turn your assumptions into facts you can try what I mentioned earlier.
Also the honda guy, must have had a sensor on its way out or his problem was something else, such as the sensor not being completely tightened up, if he removed and re-bolted the sensor as there is no way his cracked manifold changed idle afrs. Besides oxygen leans afrs it does not make them richer.
I'm sorry but that is not something I will believe.
Marios
Old Jul 17, 2020 | 10:56 AM
Marios
Sure Marios, if you say so.
the mixture reading lean would lead to a positive fuel trim as the ecu would add fuel to compensate for what it thinks is a lean condition.
Old Jul 17, 2020 | 11:17 AM
Evo8cy's Avatar
It seems that you did not understand what I said. The o2 feedback will be lean and since the ecu will compensate, the actual afrs will be back to normal, and will not be richer, and so if you use an afr gauge you will see that the afrs are how they are supposed to, stoicho-metric i,e, or whatever your tuner set them up to be. So idle condition and operation of the engine will not be affected.
This only happens though when there is a big opening on the exhaust system, otherwise the o2 sensor is not affected as it only needs a small amount of gasses to function properly. A very small leak does not dilute the amount of gasses coming from the engine. Or during winter time where the exhaust gasses contain increased amount of un burnt oxygen molecules, since the inlet air is denser in oxygen.
And yes I do say so. Now whether you agree with that or not, it really makes no difference to me.
Marios
Old Jul 17, 2020 | 03:36 PM
Pal215's Avatar
OP,
It can be tuned out, but as a temporary solution you could increase your idle speed using the BISS and see if it helps keep the car running when coming to a stop. It's likely an issue with what the gents are discussing above with too much fuel being dumped in.
Old Jul 17, 2020 | 06:16 PM
Lumpy Sticks's Avatar
5 Year Member
Marios
Funny you say that. I had a warped flange on the Dp where it meets the cat. It was leaking badly from about 1/4 of the gasket. Idles afr was extra lean, then normal, then extra lean and back to normal. It wouldn't make up its mind. Even when I went to an aem ECU, with a full time functioning wideband o2 (not measured from the o2 housing but closer to the cat), it did the same thing. After fixing the exhaust leak (again where it meets the cat) the problem was solved.
Old Jul 18, 2020 | 12:13 AM
Matz's Avatar
Thanks for all of the feedback, everyone. So it turns out that I went with the simplest approach first, which was to clean my garage and leave the Evo idling for 20 minutes. After doing that, it idles great at stops. Steady RPMs and doesn't die on me anymore. Fingers crossed.
bossmangunit
Jan 24, 2016 01:45 PM
formerSTIowner
Nov 7, 2013 05:29 AM
Crusher_13
18
Jan 13, 2012 06:49 AM
mostafa911
Apr 15, 2010 02:50 PM
ccboy37373
Jun 16, 2008 11:30 PM
