CAR FLAGGED FOR CA State REF "PLEASE HELP"
Old Sep 1, 2020 | 01:19 PM
  #106
1chi's Avatar
Yes, it is modded, pretty much the same mods as yours.
Fortunately, since I'm not originally from CA, I will be able to register in my home state.
I'm able to go back to stock also just to pass state ref, but that's too much of a hassle for me.
Old Sep 1, 2020 | 02:20 PM
  #107
Jaraxle's Avatar
CA is nuts... I am in NY and if the ECU says everything is ok, and there is a CAT on there; your good to go... The CAT doesn't even have to be OEM or EPA, although I now have an EPA certified CAT on her... I have an OEM cat hanging on the wall with 20kmi on it, perhaps I should eBay that sucker.
I had no idea CA was this detailed in making sure that you haven't changed anything.
Old Sep 1, 2020 | 03:29 PM
  #108
kaj's Avatar
kaj
I'm honestly surprised we have the time and resources to get so nitpicky. Though selecting cars at random is pretty simple and does nothing but bring in money, it doesn't seem like they would get enough to make a difference. I really don't understand.
Old Sep 1, 2020 | 04:33 PM
  #109
1chi's Avatar
It seems to me they're trying to get as many of our cars off the road as possible, for being notorious gross polluters.
Old Sep 2, 2020 | 01:07 PM
  #110
Spooled_IX's Avatar
I'm sure this whole thing is an expense. The fee for the referee is a whopping $12 and you only pay when/if you pass. Plus all the admin overhead on finding, flagging,inspecting and processing everything. CA lost money on my car since they had to inspect it twice and all the back and forth reviewing/approving documents.
Old Sep 3, 2020 | 03:16 AM
  #111
Name User's Avatar
Do I hate California more than I love my eyes?
https://dsportmag.com/the-cars/featu...bishi-exo-evo/
https://www.bar.ca.gov/Consumer/Refe..._Vehicles.aspx
I wonder if we can overwhelm their system the way LA had to shut down tickets for red light cameras. Somehow everybody is going to need to get reffed.
Old Sep 10, 2020 | 03:26 PM
  #112
ka_ka12's Avatar
Originally Posted by 2006EvoIXer
To pass ref, you can buy a spare ecu for flashing and keeping your original with stock tune. I can build any size turbo (up to size similar to FP Black) and make it look like stock 9 turbo. You can swap injectors, exhaust, and ecu for smog every 2 years. Unfortunately, the cams will need to stay stock if you don't want the huge headache of swapping it since timing belt has to come off to swap. You can still make up to 400whp on 91 and 500whp on E85 with stock cams and still be able to easily swap back for smog. Anything more will need a lot of work to swap every 2 years (cams, intake and exhaust manifolds, smog equipment, etc).
has anybody tried to tune their car with maf translator pro since it bypasses ecu
Old Sep 11, 2020 | 06:39 AM
  #113
RazorLab's Avatar
It doesn't bypass the ECU, it intercepts the signal between the MAF and the ECU.
Back when piggybacks where the only way to tune, they where mediocre at best, now that there is a ton of support for the OEM ECU, piggybacks are trash.
If you want to use a piggyback for just smog purposes, find a S-AFC for super cheap and use that.
Old Sep 11, 2020 | 06:48 AM
  #114
TurboSid's Avatar
haven't read the entire thread but did OP try contacting VW Customer Support? They're experts in passing smog tests.
Old Sep 25, 2020 | 03:47 PM
  #115
G20's Avatar
G20
Well, I'm in the same boat with the OP now. Found my "very stock" X MR has to visit referee when I was in for smog. It looks like they have a crack down campaign on tuned ecu. I called in and they made me a "phone call" appointment first. They sent me a PDF document basically saying that they think my ecu is modified (copied and pasted below). Very sh!tty. It looks like the future of our tuning cars in California will be gone soon. Just a special downpipe with tuned for 91 and e85. My options are either (1) put back the downpipe and flash the oem tune back (2) sell the car to another out of state enthusiasm. The car is well taken care of and clean, hate to let it go. Below is the text content as-is from the ref PDF attached in the email they sent. It's so suck.
The software in your vehicle’s engine management computer doesn’t match what the vehicle manufacturer produced. If it has modified programing, it is likely due to the computer being flashed with an illegal software program. Once an illegal flash has been programmed into a vehicle computer, restoring the correct flash can be difficult and complicated. Some flashes can also modify or damage the programming on other modules in the vehicle, such as ABS or Air bag control modules. If that is the case, these modules may need to be replaced or reprogrammed. In some cases, the only way to correct the problem is to purchase a new computer and have the dealer install the correct flash.
FOR SUBMITTING PROOF OF REPAIRS/CORRECTIONS TO THE REFEREE:
BY FAX: 916-244-2629
BY EMAIL: REFDOCS@FOUNDATIONCCC.ORG
Please add your name, telephone number, license plate number and allow up to 3 business days to be processed and contacted by phone.
Old Sep 25, 2020 | 09:08 PM
  #116
Chowgp's Avatar
I would put back the stock down pipe and retune if I were you. Not much effort to do and after you pass ref and smog, retune and enjoy again. I wish my car was that easy to put back to stock. ☹️
Old Nov 9, 2020 | 01:43 PM
  #117
ixSkyflakes's Avatar
Wanted to make a new account to chime in here. My car was also flagged before the smog tech touched it. Like others in the thread, it has passed all previous smogs on the bar website. I did refuse the ECU recall as there is a tune, so perhaps this was cause for audit as someone else mentioned. I have some time to swap back the stock parts before the appointment in early December, just trying not to feel targeted after reading the replies
Old Dec 18, 2020 | 07:27 PM
  #118
shortround13's Avatar
are they able to tell if you are running a piggyback tuner when you go in to get smog check? interested because I'm researching a piggy back and of course the site gives the warning "not for road use" but, if otherwise parts are smog/CARB legal will they know I'm running a piggyback when they plug in?
Old Dec 18, 2020 | 11:17 PM
  #119
kaj's Avatar
kaj
RpVilleneuve
Mar 20, 2017 08:38 AM
DIDYSIS
Dec 3, 2009 08:14 AM
miked420
Northwest Region
12
Nov 12, 2006 03:34 PM
EVOboostVIII
May 9, 2005 07:47 PM
