Who else got fried coil packs with the Emanage?
Originally Posted by TURBODAWG
Is the ignition coil issue solved yet or is still a problem??
Brian
Brian
SO i should probably be all set then, providing it is a proper installation. I know it seems to be a random issue, but i would like the input to help convince me to shell out the cash for it!!
Hi everybody. I'm back
I will be trying out the same E Manage I had last year on a different Evo. First I will try it without the optional ignition harness. I was told that power still goes into the coil packs whenever the car is on the ON position, car running or not.
After seeing if that is the exact cause of the problem, I will hook up the ignition harness, as well as this other setup that someone told me to try. The thing has a GReddy part number, but nobody stocks it. It is SUPPOSED to stop the coil frying from happening.
I should have results in a week or so.
Originally Posted by Incognito
I have that optional Mitsubishi grounding kit on my car. It has some thick *** cables on it. I'm 110% sure that those cables are installed at the exact correct points as per the instructions that came with them.
also sorry, but does mitsubishi have an upgraded OEM grounding kit???????
