Who else got fried coil packs with the Emanage?
Old May 20, 2006 | 08:19 PM
  #76
punker9474's Avatar
Anybody? Please help!
Old May 21, 2006 | 07:07 PM
  #77
punker9474's Avatar
Somebody???
Old May 21, 2006 | 07:55 PM
  #78
punker9474's Avatar
I want to try the "diode" fix you guys have tried but I'm a little fuzzy on the logic.
I know that the problem is that the e-Manage is not allowing the coil packs to zero out. Because they are in a constant "on" status, they burn out.
I know that a diode allows current to only travel in one direction. What I'm not getting is that if I put a Diode in the line, wouldn't that keep all current from flowing to the coil packs? I mean I want current to flow to the coil packs but when it's done to zero out. Am I correct in this thinking or am I way off. A little help needed here please.
Also I remember somebody saying that they ordered that Ignition Signal Adapter #2 from GReddy. Does anybody know if this is the solution?
Old May 21, 2006 | 09:23 PM
  #79
FastEvoFL's Avatar
Hey there. Well its hard to say that anything is wrong so far. I've left my car on for a couple minutes but zero problems. The diode idea seems like a logical answer to it but that would mean you were getting voltages back to the unit and not to the coils. Diodes work like check valves it goes in one way but not the other. If you put in a diode you really aren't stopping anything i feel.
Draw the circuit diagram to it and youll see what I mean.
What you really want is to ground the signal as soon as there is no rpms! There's def some simple fix to it but who is really going to want to venture into it! But then that would be ven trickier as turning on the car would probably confuse everything
Old May 24, 2006 | 04:43 AM
  #80
Visut_p's Avatar
Originally Posted by punker9474
Sorry to revive an old thread but I'm still having an issue w/ this. I was wondering if you had to change anything with your tune once you installed this? Did you keep the tuning w/ your fuel AND ignition timing and just install this? Thanks for any help.
After I fried my coil pack, I had to changing the tuning recipe. So at that time, I only tune the fuel ratio. After I install this device, I pulled back my old tuning recipe (a/f ratio and ignition timing).
Old May 24, 2006 | 08:17 PM
  #81
punker9474's Avatar
So no problems since installing the Ignition adapter? Thanks for the input.
Old Mar 27, 2007 | 05:50 PM
  #82
Fusion Ed's Avatar
Old thread, but I made my own 'adaptor' to ensure the coils are off when they should be, and all is well. In fact the e-manage on the evo was very nice to map indeed.
Ed
Old Jan 9, 2008 | 11:25 PM
  #83
Dorikun's Avatar
Um, if no one has figured out the A/C issue... when you turn a car's a/c on, the alternator and timing(advance) sometimes kicks in... it has something to do with electrical components I'm sure...
11secEVO7
14
Feb 23, 2017 11:27 AM
fugiwara
18
Jan 2, 2017 06:24 AM
Rossi_24
May 21, 2016 09:09 AM
brk4sti
11
May 15, 2011 06:45 PM
grubiaco
Lancer Engine Management / Tuning Forums
Aug 22, 2006 07:30 AM
