engine light flashing
Old Aug 28, 2004 | 04:17 AM
BJai02's Avatar
Question engine light flashing
Does anyone know what it means when I see my service engine light flashing for 6 to 8 times? I read through the Autronic user manual but I can't find anything about the engine light flashing.
This board is not very active at all, where else can I find more info and help with my Evo8 Autronic?
Old Aug 28, 2004 | 05:04 AM
Sentinal's Avatar
How many miles are on the car? might just be time for a tuneup.
Old Aug 28, 2004 | 10:47 AM
Mark S's Avatar
Your check light will flash a code count the flashes,It will flash fast then stop and flash again this will tell you the fault.
Mark
Old Aug 28, 2004 | 10:29 PM
BJai02's Avatar
Hi Mark S,
I have a couple different code. I have 2 flashes before the engine started.
8 flashes right after the engine started. After a few 8 flashes, it becomes 9 flashes. 9-flashes goes on for 2-3 times then there is no more engine lights.
Does it mean something to you?
Sorry for going off topic, does anyone in California using 91 octane with Autronic? I want to compare my maps to yours, since I experiences some major knocks in mid range (peak torque). I had to retard over 5-7 degrees of ignition timing to eliminate them.
Old Aug 29, 2004 | 04:29 AM
Mark S's Avatar
They are error codes try the car with the Ignition on and alarm switched off ready to start leave like this until all flashes finished, Then count them and call where you got it from they will be able to tell you what the fault is.
Mark
Old Sep 12, 2004 | 08:02 AM
Dyno4mance's Avatar
You will need to contact Steve Nichols with Aussie Imports...The Number is (859) 983 4964....he is in KY so it will be EST
Hope this helps
Old Sep 12, 2004 | 08:20 AM
Nad1370's Avatar
Do you feel the car jerking or losing power?
Usually when it's flashing like that while driving, ECU see's cylinder misfire.
Have the code pulled to confirm this.
Old Sep 12, 2004 | 09:42 AM
plokivos's Avatar
when it flashes, it means you're in big trouble. That's immediate engine service code. Don't drive your car and go see your dealer or someone about that.
GO NOW!
any small engine codes like misfire or Lack of CAT will be stationary lit, but when the engine needs immediate attention, it'll start to flash.
Old Sep 15, 2004 | 12:23 AM
BJai02's Avatar
Thanks for the advice. But note that Autronic is a stand alone ECU, the dealer can't do nothing about it
Old Sep 22, 2004 | 10:30 AM
TomeiEvo's Avatar
Can you decipher you flash code correctly? If you can I will be able to tell you whats wrong or at least close to it. I have 2 evo's with the Autronic on it and my tuner is one of the top tuners in Australia that will know everything about it.
Switch your ignition off. then turn it on. Basically the flashes will be in 0.5 sec pauses in a series and goes off for 2.5 sec before the next set of flashes come on. If there is a multiple error, there will be a 3 sec break in between the first set of flashes for ex. 2-4 (3 sec pause) 3-4 ( 3 sec pause) 1-1 ( 3 sec pause etc..), This means you have 3 sets of problems ( just as an ex).
Easiest way, get a laptop, install the software provided with it and log on the ecu with the connector harness from the serial port of the laptop. Becareful, the ignition key has to be on before you turn on your laptop to register correctly. Once in it, go to Menu M2 or M3 and scroll down to Ecu error history and press enter. The log will show you all the error that has happened in the last few cycles.
Good luck!!
Old Sep 22, 2004 | 10:45 AM
BJai02's Avatar
Good luck!!
Very nice of you. But I've already reset my lights with my laptop. I am not sure what they were, but they just havn't came back yet. Just keep my fingers crossed.
Thanks for the offering!
familymr
12
Apr 7, 2011 10:44 AM
andy hiralall
Nov 21, 2009 07:46 PM
tweakdsm
16
Nov 10, 2009 07:15 PM
turboevo8
Sep 5, 2009 02:37 AM
HuskerEVO
Jun 25, 2005 08:54 PM
