Turbo on my ES
Old Oct 9, 2004 | 07:23 PM
OZrallyats's Avatar
Last I heard, the reason you need to gaskets on the pipe is because the turbo kit was originally built for a mirage(?), which had an engine almost identical to ours, but it sat slightly a little taller. So when you put that kit on our cars, there is a little gap between the manifold and the downpipe, which some people have accounted for by doubling up gaskets, I know another guy who just took it into a shop and had the pipe welded a little longer.
Old Oct 24, 2004 | 05:45 PM
acs_guitars's Avatar
Turbo Kit
If that kit was originally for the Mirage, then the engine height is the problem. Aside from the different engine tags (4G93 Mirage and 4G94 Lancer), the motor mounted a little lower in the Mirage, but the engines have the same deck height. A 4G94 is an over-bored version 4G93.... I believe other than that the dimensions of the engine are the same.
Hayk
Oct 19, 2016 03:17 PM
Hayk
Feb 4, 2016 07:23 AM
Brian@RRM
May 10, 2011 09:56 PM
asimpson719
14
Apr 8, 2009 07:58 PM
munichflash
Lancer Troubleshooting
Oct 5, 2003 09:42 PM
