Want to build a custom turbo setup
Old Nov 4, 2004 | 10:46 PM
  #31
OZ-Guy's Avatar
oh ok.. but what do i do about the internal wastegate? will it not even open since there isn't the right amount of pressure?
So my modified list looks like this:
up pipe and downpipe,
boost gauge
turbo
wastegate
bov and flange kit
intercooler
fmu
ic piping
braided oil feed line
rubber oil return line
Old Nov 4, 2004 | 10:49 PM
  #32
OZ-Guy's Avatar
so where does the wastegate go in all this piping? the bov goes on the cooled side between the front mount and the throttle body right?
Old Nov 4, 2004 | 11:07 PM
  #33
rhyzin's Avatar
see that lighter silver thing that looks like a grenade? if you have the RRM up/down pipe, the wastegate flange should be there. if not, it goes between the turbo and engine exhaust on the first J-pipe.
just follow the pic. and pick up a turbo book by either Corky Bell or A. Graham Bell. there's also a lot of pics of the RRM turbo kit as well as others all over this turbo forum. take a look around.
Old Nov 4, 2004 | 11:11 PM
  #34
OZ-Guy's Avatar
awesome! you have been a great great help! hopefully the mods will take notice of this!
Old Nov 4, 2004 | 11:27 PM
  #35
OZ-Guy's Avatar
according to your sticky i need an S-AFC and a fuel pump.. is this correct?
Old Nov 4, 2004 | 11:41 PM
  #36
pgmike's Avatar
you would need a fuel pump so that you arent fuel starved bc of all the fuel it will want with the much greater amoutn of air.
you dont "need" and safc for such low boost but it would help to get a little more power out of the setup but it wont hurt you if you dotn have it on <8psi.
Old Nov 4, 2004 | 11:44 PM
  #37
OZ-Guy's Avatar
ok. I'm not that big on tuning "YET" but I'm just starting out.. I'll get it soon or later though..
Old Nov 5, 2004 | 12:07 AM
  #38
OZ-Guy's Avatar
How does this look? I think this is everything I need? Correct me If I'm wrong.
turbo
uppipe
downpipe
boost gauge
wastegate
bov and flange kit
intercooler
boost sensitive FPR
ic piping
flanges
silicone pipe connectors
fuel pump
Also, where does the MAF go? right after the air filter as usual? I'm pretty sure I got this all figured out! Thanks rhyzin!
Old Nov 5, 2004 | 12:25 AM
  #39
pgmike's Avatar
you may want to include a turbo timer in there just to keep things in better condition and maybe a pyrometer jsut to make sure things arent going wrong and melting crap. oh and dont forget a gauge pod lol. oh one thing you will have to get if you get the rrm up and down pipes is a slim line fan to replace the oem ones bc they will need to be removed to make room for the turbo and pipes. you will need to to put it on teh front of your radiator.
you know what all silicon pipe connectors you need (what pipes the connect)?
yes, you can put the MAF it right after the filter.
Old Nov 5, 2004 | 06:53 AM
  #40
HobieKopek's Avatar
Click
Click
Click
Click
Old Nov 5, 2004 | 07:57 AM
  #41
OZ-Guy's Avatar
alright! thanks again pgmike! With help from you and rhyzin i feel pretty confident going into this now. we'll see how everything works out!
JDEve
Jun 22, 2015 08:27 AM
gregivq
Nov 17, 2004 02:10 PM
BennettOZ
Sep 11, 2004 08:03 PM
initialDRacer
Apr 25, 2003 07:29 AM
