stock injectors during boost STILL rich?!? guru's help
Old Jul 21, 2005 | 03:32 PM
GreenPsycho's Avatar
lemme start off by explaining the scenario: i'm having ripp put on there stg2 on my lancer right now. there are also doing a brand new tune for the kit because of there newest upgrades to the fuel system.
old fuel system:
in take fuel pump
rr fpr
310cc or higher injectors
new fuel system:
in line fuel pump
rr fpr
stock injectors and a supplimental atomizing injector right before the TB
now with the old system, tuning was pretty straight forward
but with the new system we are running into problems: you would think at high boost (10psi or so) stock injectors would flow and then you control the atomizer to supply the rest of the fuel (theoretically how it should work)
however, ripp has found on my car at 10psi, the atomizer could flow little to no fuel so only stock injectors are flowing and it STILL runs super rich. really really rich, almost to the point that its not safe to drive long distances.
no cel codes were thrown (except maf exceeds barometric pressure, which is expected) and ripp hasn't run into this problem on any of the other cars with the new fuel setup. it wouldn't make sense that our stock injectors (220cc or whatever they are) are running like 3xx cc's but they are.
its speculated that perhaps the stockers can't hold the excess fuel pressure and are just dripping with fuel, but i don't know. this is also the first lancer they are tuning with the new setup, so there is a bit of a learning curve
normally i'd figure "its there problem let them figure it out" but i really need my car back asap, so if anyone has any thoughts on the problem, let me know. i thought maybe someone has come across this problem before and found a solution.
Old Jul 21, 2005 | 03:34 PM
Alchemist's Avatar
have them reinstall the 310's with the supplemental injector and see what happens This is what you get for having too much fuel flow through that rail
Old Jul 21, 2005 | 03:42 PM
yeah, that was my thought too, just get some low injectors. or we could just skip the supplimental injectors and go back to the old way which on stg2 was like 410cc or something
Old Jul 21, 2005 | 03:49 PM
Alchemist's Avatar
well, stock is 240, you've got some 310's lying around from the original setup (or don't you?). I'd give those a shot first then look to moving up.
But I don't know jack about FI fuel requirements.
Old Jul 21, 2005 | 03:57 PM
yeah, ripps got everything at the shop. going down tomorrow and hopefully help hammer some stuff out.
i would just say "screw it, slap in the 410's" but the reason for the new system is it reduces rough idle and all the other problems associated with running huge aftermarket injectors, so i would like to try and get this to work
Old Jul 21, 2005 | 04:05 PM
Melaz425's Avatar
So Jay would you be going back to stage 1? Or is it stage 2 because it has a more aggressive tune?
Old Jul 21, 2005 | 04:14 PM
no, its stg2 cause of the boost i'm running (10/11 psi). its not a question of taking steps back performance wise, it just comes down to the fuel setup configuration
Old Jul 23, 2005 | 07:28 PM
KillahB's Avatar
What's your base pressure set at?
Old Jul 23, 2005 | 09:37 PM
specific details huh? yeah, i guess that would be useful, but alas, i have none
the problem could be 2 fold: first is the wiring could have been screwed up to begin with, they aren't really sure yet so they are double checking. second and probably most likely is that hte stock injectors can't take the added pressure on the lines. i want to say 80psi, but i really don't know, i could be making that up
so the solution i hope that works is to slap on some 310cc injectors that CAN hold the excess pressure, then when boost raises extra fuel will be supplied via the supplimental injector. but at the same time you get a nice smooth idle cause you aren't running 410cc or something
mrfred
58
Jan 4, 2016 06:09 PM
rawkus
Aug 7, 2009 08:47 AM
GreenPsycho
56
Aug 5, 2005 05:35 PM
RIPPMODS
Lancer Vendor Classifieds
220
Jan 24, 2005 02:41 PM
RIPPMODS
46
Jan 31, 2003 09:40 AM
