Converting injectors.....
Old Jul 26, 2005 | 04:36 PM
Lancerguy'03's Avatar
i was lookin around the electrial store today and it sparked a crazy idea. if i can rember right Evo Injectors are high Impedence....and the Lancer needs Low Impendence.....well the diff. is just Ohms....so why couldt u put a resistor in series to limt the Ohms and make low impedence injectors?
im probly WAYYYY of in my own world so somebody pull me back down.....
Old Jul 26, 2005 | 04:51 PM
silkymp's Avatar
the lancers are high and the evos are low i believe. Some people i think are running lows off of the eclipses. There should be a thread on this forum somewhere.
Old Jul 26, 2005 | 06:03 PM
HobieKopek's Avatar
Silky is correct. Resistor packs can be used on peak & hold (low imp) injectors to make them function like saturated (high imp) injectors. If you do plan on using P&H, make sure you do this, otherwise you risk fuel system failure, and possibly other problems. If I remember correctly there have been fried ECU's on Mirages because of this. If you dig a bit on the forums you'll find more about this though. Bahamut and the other 'Rage guys are awfully helpful.
Old Jul 29, 2005 | 11:29 AM
KillahB's Avatar
One Mirager was using 450cc out of an Eclipse, no resistor pack. His car ran fine .... for a while. Then it started doing some weird stuff and misfiring and essentially stopped working. Traced it to a bad ECU, caused by reading the wrong impedance over time.
bbyevo8u
15
Nov 2, 2016 06:04 PM
jameswwt
Nov 19, 2014 05:24 AM
LetItBreath
Oct 17, 2007 10:47 AM
Juiced
Oct 16, 2005 04:41 PM
evo_artist
Mar 7, 2005 09:11 PM
