First Dyno Run....*help*
Old Oct 10, 2005 | 06:57 PM
AznFlip's Avatar
Unhappy First Dyno Run....*help*
I went to a dyno shop today and had my first run. It pushed 152.4whp and 151.4 wtq @5psi and it's running super lean (18.0 a/f ratio)
The guy over there told me that my fmu might not be working right and probably my fuel pump also, so I'll check those tomorrow. So I'm not going to be boosting until it's fixed.
You guys have any idea why it's running super lean?
Old Oct 10, 2005 | 07:07 PM
datdjrobp's Avatar
rhyz and HK will fix it and you'll shortly be pushing 200whp. i know it!
Old Oct 10, 2005 | 07:08 PM
AznFlip's Avatar
Thanks, just sad. But I was expecting like this to happen.
Old Oct 10, 2005 | 07:11 PM
Evodreamer28's Avatar
Dam dude thats really lean
Old Oct 10, 2005 | 07:16 PM
Lancerguy'03's Avatar
check ur PM AZN!!
Old Oct 10, 2005 | 07:18 PM
AznFlip's Avatar
Originally Posted by Lancerguy'03
check ur PM AZN!!
Thanks, probably I'll call you tomorrow?
Btw, after my dyno run, it remind me of you right away because it's similar problem you had.
Old Oct 10, 2005 | 07:23 PM
nevermind....i just checked ur PM....yall tommorw will work after 4CST!
i had the same problem! lol....u should be back on the road in no time....hopefully
Old Oct 10, 2005 | 07:26 PM
AznFlip's Avatar
^Cool, thanks.
Old Oct 10, 2005 | 07:27 PM
yeah ill be up 10WEST witch is 12CST......ill be up
LOL....using the fourms as instant messeger....not very instant....but yeah ^^^
Old Oct 10, 2005 | 07:40 PM
03OZTurbo's Avatar
Im pretty sure i have the same problem super lean
Old Oct 10, 2005 | 07:48 PM
HobieKopek's Avatar
First off which FMU disk are you using? Any and all fuel system info would help.
Old Oct 10, 2005 | 07:51 PM
AznFlip's Avatar
Using Blox 12:1 FMU and TRE 255lhp fuel pump.
Old Oct 10, 2005 | 07:52 PM
datdjrobp's Avatar
so would a conclusion to my grad school essay. i'll shut up now.
oh, and i find it highly upsetting that i know every single component of Azn's turbo, and I could probably recite the price he paid for every item. now we just need to get that sumbish working right!!
Old Oct 10, 2005 | 07:58 PM
HobieKopek's Avatar
Well, assuming FMU's normally do provide acceptable AFR ranges (and I can only assume they do because I don't remember anyone who runs an FMU setup mentioning WBO2 readings), they were probably right. Either the FMU, fuel pump or both are crappin' out. Is this only happening at 5psi or does the AFR gradually raise building up to it? like 15.0 at 4psi or is it normally rich then shooting up? Is there noticable knock? Are you certain the WBO2 was calibrated correctly? Tryin' to think of variables to rule out, but I'm also writing a lot of papers all week so my brain's kinda in left field....
Old Oct 10, 2005 | 08:02 PM
impetus19's Avatar
Any exhaust leak will register leaner than normal AFR's, b/c of oxygen getting into the exhaust..
