Boostin in T-minus 3 weeks
Old May 24, 2006 | 05:39 PM
ozrally0303's Avatar
just got finished wit mine and guess wat the damn stock evo intercooler acually bolts up u just got a make a lil piece to hold the top in but other then that 2 bottom bolts fit perfect check it out
Old May 24, 2006 | 07:05 PM
Sicktght311's Avatar
Looks hotness. I'm sticking with the stock bumper for now so the evo intercooler was a little too big for my stuff. I went with an 18x6.5x3 which should match up nicely. I'm putting it on this weekend so i'm hoping for no major modification needed.
Old May 24, 2006 | 07:26 PM
ya man my intercooler is way over kill but couldnt pass up a good deal good luck wit ur project boost is adicting tho so watch out
Old May 25, 2006 | 06:13 AM
Heres a question for you turbo guys. I'm heading out to the hardware store this weekend for the oil fittings. What sizes do i need?
I need the Oil feed for the plug above the oil filter. I think i remember seeing 3/8 NPT. The oil line i have has a threaded fitting at the ends (which i'm sure all do). Also i need the fittings for the oil pan and whatever drill and tap sizes. The turbo i got came with the flexible oil return hose but i think i wanna replace it with something a little more sturdy so what do you guys suggest?
Old May 25, 2006 | 03:26 PM
Z_Lancer_Man's Avatar
I'm not sure about the fitting for above the oil filter since I used whatever RRM includes in their kit. I do know however that RRM uses a 3/8" NPT fitting for the tap, also 3/8" NPT at the oil pan for the oil return. RRM also includes a sturdy return line from the turbo that goes about half way and then they use some heater hose for the remainder of the way.
Old May 26, 2006 | 07:37 AM
Anyone?
Old May 26, 2006 | 08:44 AM
Got it myself....
3/8" NPT drill and tap set for oil return with a -10AN line
3/8" NPT to 1/4" NPT for the oil feed line, 8mm hex plug above the oil filter
Startin the install of the FMU, Fuel Pump, and Intercooler (just mounting it up) as soon as i get home from work today. Gotta get emissions tested next week (before i turbo so i know i'll pass hehe). Then Turbo install June 2nd or 9th!
Old May 27, 2006 | 02:12 PM
Well got the fuel pump installed today. 255 walbro. Things sounds like a god damn leaf blower. So now my car will have what looks like a big hair dryer and it will sound like a leaf blower....hmmm its a conspiracy
Old May 27, 2006 | 03:50 PM
funny **** man i just got mine in to i hope ur wastegate is on the front of ur turbo cause i went to put mine in and it hits a bracket i had to grind the damn thing off but so far so good now if u need pics of anything let me know
Old May 27, 2006 | 06:47 PM
I know! That Walbro is freaking loud.
Old May 27, 2006 | 07:19 PM
I'm having a little stumble at idle now. When i come to a stop it kinda dips down to about 500, mabe hits 400 rpms for a few seconds, then stablizes back at 7-8 after about 2 seconds. Maybe just running a little richer now?
Old May 27, 2006 | 07:58 PM
You are definately gonna be running richer. You'll soon see your tail pipe black and your fuel efficiency down the tube
Old May 27, 2006 | 08:01 PM
Go2fast's Avatar
Does it keep doing it like rev up then back down. Like it surges at idle.
If so, i had the same problem!! It was a vaccum leak. My line to the fmu exploded.lol but i fixed it and the idle was fine.
Old May 27, 2006 | 08:18 PM
Naa, it just dips down for a few seconds and then normalizes. I'm not really worried about it. I'm putting on the FMU and intercooler tomorrow. Getting the car inspected next week. and then turbo shortly after
Old May 27, 2006 | 08:33 PM
Good luck with install!
