RRM turbo
Old Apr 28, 2003 | 01:46 PM
jon527's Avatar
RRM turbo
With RRM's turbo your header are no longer needed Right?
Old Apr 28, 2003 | 01:49 PM
uranium9v's Avatar
uses stock header as the turbo manifold.
Old Apr 28, 2003 | 05:41 PM
Boeturbolancer's Avatar
Depends on what you want and fitment. I chose to keep my header and the few extra hp by fitting the turbo w/header. If you want to save yourself some time/frustrations and your willing to lose a couple hp your better off going with the stock header. You can get some hp back by just beating the cat out if you'd like.
Old Apr 28, 2003 | 05:55 PM
mikenuts86's Avatar
from what i know, rrm's header is the only header that will fit with the turbo kit besides the stock one of course
Old Apr 28, 2003 | 05:58 PM
Bitnode's Avatar
does RRM's header fit the turbo kit? or would i be better off putting the stock one back on? im thinking of ordering the turbo as soon as i can save up the ca$h...
Old Apr 28, 2003 | 06:00 PM
RRM header does "fit" RRM kit but there are some space/piping concerns/issues that require a bit of fitment. It does work though as i did it. Just stating that time and ease is on the stock headers side. I like the header for many reasons so i kept it on the car.
Old Apr 29, 2003 | 06:53 AM
Bitnode's Avatar
cooool.. now.. do you think i should go for the intercooled kit? is it worth it? or should i save myself a grand and just get the non-intercooled?
Old Apr 29, 2003 | 11:03 AM
M3 STYLELAB's Avatar
bitnode i don't mean to jack you thread but i think this might help you
boe:
how much more of a hassle is it?
was it a hassle just for install or maintaining it too?
did you incure additional costs for extra piping from RRM?
FInally: What do you honestly think of the h.p difference?
thankx in advance boe
Old Apr 30, 2003 | 09:04 PM
Definately non-intercooled is way to go. Unless you get into serious motor work...rods/pistons/cam/crank/head/vlvs/ you're not going to need intercooler as you'll always be running lower boosts. On lower boosts you'll only get like 5 hp from the intercooler. Intercooler is a factor at higher boost levels which as i said... As for M3--For me it wasn't much hassle just took about an extra hour+, but i'm mr. mechanic... There is no real maintenance other than the usual. Of course every now and then i check things for tightness but all is always well... As for HP difference you'll lose about 5-10 hp if you keep the cats. For me i already had the header installed so adding the turbo to it seemed better than wasting 350+ bucks for something i wouldn't use again. Hope all this helps.
Old Apr 30, 2003 | 09:48 PM
Bitnode's Avatar
Yeah man. thats great! From your advice I dont think ill get the intercooler... you saved me a grand! thanx bro!
Old Apr 30, 2003 | 10:56 PM
Anytime...
CombatSpeed
22
Jun 15, 2015 10:07 AM
RallyAzn04
Apr 3, 2009 03:57 PM
zboy's_lancer
143
Apr 14, 2008 02:17 PM
splurge3188
Feb 9, 2005 05:07 PM
Probleminfected
Jan 9, 2004 10:43 AM
