Yet another 16g
Old Jan 16, 2007 | 06:20 AM
  #31
0zlancer's Avatar
last vaccum question i think.. does the wastegate actuator vaccum come from the cold air intake side, or the compressed side?
Old Jan 16, 2007 | 08:02 PM
  #32
01G_WRX_02's Avatar
the black pipe the bolted to the outlet of the turbo has a little nipple on. just connect that to the Wastegate hose.
here you can see the black pipe
Old Jan 17, 2007 | 12:22 PM
  #33
0zlancer's Avatar
ok, so i started her up, and she purred like a kitten, but my wastegate actuator, and stock evo 8 BOV didnt seem to be working (my fmu is off the same line, but my air/fuel gauge says the fmu is working)? Anyone have any things that i should check (i know its vaccum related)? The wastegate actuator, is that suppose to be installed with the wastegate all the way down?
Old Jan 20, 2007 | 03:29 PM
  #34
0zlancer's Avatar
ok, so I think I may have f-ed something up.. I am thinking it may be valves, but i have no idea. It makes a sort of rattling sound at high RPM's, but its only when letting off the throttle....oh and this is without the turbo on and back to stock..Any ideas?
Edit: I may have just thought of something, i am running mobil 1 10w30 fully synthetic, and when pulling the stick it just seems way to thin (oil weight). I am going to go buy some good old valvoline and give that a shot.
Old Jan 20, 2007 | 04:05 PM
  #35
omarboy25's Avatar
its definitely the oil our cars love OIL
Old Jan 20, 2007 | 04:12 PM
  #36
0zlancer's Avatar
I'll give it a shot thanks omarboy.
Old Feb 19, 2007 | 12:43 PM
  #37
Frankracer88's Avatar
so have you figured out what happened?
And im just starting to build this, so im interesting i knowing all the diferent plumbing pieces that you ended up needing.
Thanks
Old Feb 20, 2007 | 12:11 PM
  #38
Newfoundlancer's Avatar
Rattle when you let off on the gas can also be as simple as your exhaust being too close to something. Have a look at that as well.
Old Mar 1, 2007 | 12:37 AM
  #39
lancerman360's Avatar
Any updates? I am planning on going the 16g route as well.
Old Mar 3, 2007 | 05:31 PM
  #40
Kid Lancer 7's Avatar
I am using the Forge Adjustable wastegate, and asked them to change the spring out to a 7lb. spring. I absolutely love this setup, IC and piping basically lines up perfectly. The way i see it is that it would almost be foolish not to.
did you have to trim your front crash bar to fit the evo ic???? i have an evo IC... and when i did the install the damm crash bar only allowed 2" of clearance space from the ground.... VERY scary!! i took off my kit cuz i moved from jersey to miami..... so im planning my 2nd attemp Very soon...
Old Mar 4, 2007 | 12:22 PM
  #41
kungfugirl's Avatar
gotta remove teh crash bar^
Old Mar 7, 2007 | 11:20 PM
  #42
Majuljo's Avatar
how much hp can the 16g turbo get our cars right away? like i get it all together iwht the parts and what will i get ? im not asking exsact but a roundish number because im really thinking of going the 16g route for my OZ anda when you put up all the parts needed i will definatly follow that. someone should jsut put a main thread on how to build a 16g turbo!!!
Old Mar 8, 2007 | 12:39 AM
  #43
ambystom01's Avatar
? That question doesn't make any sense. What PSI are you running? Intercooled or non-intercooled? What supporting mods? What kind of tuning? It's not like you just bolt on a turbo and magically gain 50 hp, there's a lot of other things to consider.
Old Mar 8, 2007 | 02:01 PM
  #44
Majuljo's Avatar
im not a retard but i guess i did leave that blank but lets just say 7 psi, intercooled, i did say just the basics just to get it running. im not wanting to know 5psi intercooled = this or 7 psi= that. just want to know basic stuff. if i get what i need how much will i gain?
Old Mar 8, 2007 | 04:22 PM
  #45
ambystom01's Avatar
You are asking "If I run this what will gain", which again isn't an easy question to answer. You could be at anything from 170 hp to 250 hp depending on other variables.
