KustomConcepts' Turbo Build
Old Sep 19, 2007 | 11:29 AM
lancerman360's Avatar
Dang I am going to have to come to the next meet yall have. I wanna see this in person and finally meet you guys.
Old Sep 19, 2007 | 11:51 AM
drucea's Avatar
Definately. You have a good looking lancer. How far is Lufkin from Spring? We have meets a lot in that area.
Old Sep 19, 2007 | 11:56 AM
Around 2 hours....doing the speed limit.
Old Sep 19, 2007 | 03:16 PM
kungfugirl's Avatar
fmu worked out?
Old Sep 19, 2007 | 10:05 PM
drucea's Avatar
Haven't actually connected it cause it's at Tim's parents house. We go to college 45 minutes away so we are going to continue on friday. But I now have a good idea of where everything goes with everyones help here and frank_boogie's pictures he sent me. I'll keep you all updated.
Old Sep 22, 2007 | 08:30 PM
iyi0521's Avatar
Looks pretty good. You need 2 slim fans for that setup?
Old Sep 23, 2007 | 06:42 AM
drucea's Avatar
Not sure. We have one on the passenger side on the front of the radiator. Everyone's been saying we'll be fine with just one. Hope so.
Old Sep 23, 2007 | 08:11 AM
KustomConcepts's Avatar
Originally Posted by SLVROZ_03
^It's not glass, but like clear plastic of sorts...they just call it glass cuz you can see through it.
It actually is like a tempered glass so its made to stand up to the heat. Here is a few pics of it, but the new one will replace the whole hose.
ya mayn youll have to make it out to the next one. Its gonna be on the 5th. ill post someting bout it this week. hope to see ya out!
Old Sep 23, 2007 | 02:11 PM
kungfugirl's Avatar
What is the purpose of the glass tube in the coolant line to the radiator? Just for show? Or does it have a practical use?
Thanks.
Old Sep 23, 2007 | 10:28 PM
Wow that looks sweet.
Old Sep 24, 2007 | 05:27 AM
drucea's Avatar
Glass tube is for show. I suppose you could use it to see if there is oil in your coolant.
Old Sep 24, 2007 | 05:50 AM
Thanks.
What he said
VVV
Old Sep 24, 2007 | 08:10 AM
drucea's Avatar
OK, new question. We don't have a boost controller yet. I've heard manual boost controllers don't hold consistent boost well, but I've also heard they hold low boost fine. I've then also heard that since we have an external wastegate set at 7 psi, we'd be safe because that would keep the boost fine. So, just to get it running, would a cheap manual boost controller be ok?
Old Sep 24, 2007 | 12:04 PM
Speed Corps's Avatar
Former Vendor
You don't need a boost controller. The stock wastegate spring pressure is fine. The problem the manual boost controllers have is only when you exceed a specific boost level depending on the turbo. So basically, it's dependent on your setup. I wouldn't be concerned if I was you. If you need to bump up the boost, just get yourself a Forge or Hallman boost controller.
Old Sep 24, 2007 | 01:27 PM
drucea's Avatar
OK cool. That's good to know. One more thing we can wait on, cause we have to wait for the turbo timer too since no one here wants to point out which wire on the back of the gauge cluster is for the speedometer, they feel it's easier to just say search. So after it's running, we will get the turbo timer on and get a boost controller. Thanks for that info.
