KustomConcepts' Turbo Build
Old Oct 1, 2007 | 01:13 PM
  #61
ThunderOZ's Avatar
Originally Posted by KustomConcepts
hahaha.... "crazy" as in u like or "crazy" not so much?
well my friend installed the rrm 16g on his 05 es and the sound is exactly the same but yours seems to last longer... By crazy I meant it sounded like it releases boost slower or draws or it longer...
Old Oct 2, 2007 | 06:45 PM
  #62
lancer2show's Avatar
Originally Posted by ThunderOZRacer
well my friend installed the rrm 16g on his 04 and the sound is exactly the same but yours seems to last longer... By crazy I meant it sounded like it releases boost slower or draws or it longer...
different bov he's running a type s. i have the gay plastic 1 on my 05 imma change out later.
if you find oil in your intercooler pipe possible the seals of the turbo are messed up.
Old Oct 2, 2007 | 06:57 PM
  #63
kungfugirl's Avatar
I feel like the seals are probably blown.
Old Oct 2, 2007 | 06:59 PM
  #64
yup. i mean it can be other things too like the valve seals or headgasket to be the worse, but i highly doubt it.
Old Oct 3, 2007 | 06:28 AM
  #65
KustomConcepts's Avatar
if i pull the pipeing and find oil how do i know if its valve seals, headgasket or just the seals on the turbo?
Old Oct 3, 2007 | 06:39 AM
  #66
if you pull the piping and find oil its the turbo most likely
Old Oct 3, 2007 | 06:50 AM
  #67
drucea's Avatar
How well will a cheap ebay manual boost controller hold up? Would it be ok to use for 7 psi?
Old Oct 4, 2007 | 07:25 AM
  #68
^^^^ bump?
Old Oct 4, 2007 | 01:18 PM
  #69
Speed Corps's Avatar
Former Vendor
I'm sure it would work fine but what is the spring in the waste gate set at? You cannot go lower than the spring pressure. If the spring is rated at 12 lbs, you can only turn it up. If your trying to lower it, it's a good idea to go with a forge waste gate actuator with a 7lb spring.
Old Oct 4, 2007 | 01:24 PM
  #70
Mirage2.0's Avatar
drucea: what injectors are you guys using?
Old Oct 5, 2007 | 09:05 AM
  #71
drucea's Avatar
We aren't sure about the wastegate spring or the injector size, but they are RC injectors and supposable huge. We are calling the guy who sold him the kit today to ask both of those questions.
Old Oct 5, 2007 | 02:11 PM
  #72
no anwser from seller yet....... well keep ya posted
Old Oct 5, 2007 | 05:38 PM
  #73
good news....
-the raspy noise we kept hearing was just the wastgate.....lol
-the smoke was just from some "fuel cleaner" i got at autozone
so the only things left are that its boosting kinda high (but that may be just that i have a cheep guage), and i need to hook up the turbo timer and boost controller when it comes in.
Old Oct 5, 2007 | 06:10 PM
  #74
kungfugirl's Avatar
stock downpipe and header?
Old Oct 6, 2007 | 08:37 AM
  #75
Mirage2.0's Avatar
So wait, how many psi are you running?
