Moment of Truth
Old Dec 11, 2007 | 08:58 AM
  #61
ambystom01's Avatar
Depends on the driver too. Don't forget they weigh quite a bit more than a lancer.
Old Dec 11, 2007 | 09:34 AM
  #62
ihearthondas's Avatar
oh i've beaten one before w/ an exhaust. it was a 30mph roll on 2nd. he was loud as sh*t but i was the one pullin away. when he spotted my car, he actually chased me down in traffic just to race me...probably thought i was an evo...only to find out he got owned by an OZ when he saw my rear lol
Old Dec 11, 2007 | 09:36 AM
  #63
ambystom01's Avatar
If all he had was an exhaust, he could easily be making less power than stock.
Old Dec 11, 2007 | 09:50 AM
  #64
senate6268's Avatar
Originally Posted by ihearthondas
^^the car is running fine actually. possibly some boost leaks here and there and the turbo starts to spool around 2300 to 2500rpm. my clutch isn't slipping when i tested it earlier on my way to work. so i dunno what's up with that. afr's im not too sure about...i think 9.0:1 when i was watching the dyno monitor during the run.
9.0:1 is way too rich if that indeed is what they were at. You'd extract a bit more power if you got them to around 11.0:1.
Old Dec 11, 2007 | 10:10 AM
  #65
Mirage2.0's Avatar
^+1
Old Dec 11, 2007 | 12:22 PM
  #66
dibsen's Avatar
You could prob get right around the 2 hondo mark if you lean up your fuel.
What are your egt's? bet they're low
Do you have any means to adjust your timing?
seems like your tuner set you up with a conservative tune. I think you can pull some more hp and still be safe.
Old Dec 11, 2007 | 02:19 PM
  #67
SLVROZ_03's Avatar
Yeah, I was going to say 9 anything :1 is too rich...even for F/I.
Old Dec 11, 2007 | 03:24 PM
  #68
lancerrally45's Avatar
well if you still have a boost leak it will run rich because you have a mass air sensor. you should really do a boost leak test then you would know if its that or your tune
Old Dec 11, 2007 | 04:32 PM
  #69
hmm...some good things to consider. thanks for the suggestions, i'll check them out when i get a chance.
Old Dec 12, 2007 | 09:41 AM
  #70
slipshft's Avatar
I agree that you should get it sealed up and tuned, also keep inmind that the hp number you get has another factor; the weight of your car. Most people seem to forget hp/weight ratio is what get you there faster or slower than the other guy (discounting bad drivers or equipment). So like Amby said, if they are heavier and making about the same hp they won't be as fast as you. So, don't pick on light cars, find the big fat heavy ones!
Old Dec 12, 2007 | 11:54 AM
  #71
ambystom01's Avatar
It's a matter of how you race too. If you took on an STi from a stop, you wouldn't stand a chance. From a roll it's entirely possible.
Old Dec 13, 2007 | 01:21 PM
  #72
jakermeister's Avatar
^I agree Power/Weight.
crcain
Nov 14, 2008 03:45 PM
SurferX
14
Jan 15, 2008 01:59 PM
freshevo8
Southeast Region
10
Sep 3, 2006 06:32 PM
thereasonsf3
Mar 8, 2004 06:50 PM
cjb
23
Sep 24, 2003 06:38 PM
