Project Lancer Beast
Old Mar 23, 2008 | 07:20 PM
  #31
lancerSE06's Avatar
Ya i just honed out the holes and ported the inlets so they lined up and had to notch out the one side for it to clear water pipe. Its a DSM header so its the same flange as the Evo sense the have a 4G63.
Old Mar 29, 2008 | 11:40 AM
  #32
lancerSE06's Avatar
I took my block up to the machine shop this week but i found out i had to bore it out .020 over to clean up the cylinder walls.
Old Mar 29, 2008 | 11:58 AM
  #33
SLVROZ_03's Avatar
You got STD pistons after you blow up that piston? Ouch man, those cyl walls are even lucky to be re-used seeing that carnage. Those rods and pistons are sick though! Even nicer than the SRPs and Eagles for my Civic build. Best of luck to yah!
Old Apr 3, 2008 | 09:13 PM
  #34
MK3Design's Avatar
Since you have an 06, you have a hydraulic clutch, how did you get your intake to clear? The lever is like straight in front of my intake on the turbo
Old Apr 4, 2008 | 05:41 PM
  #35
lancerSE06's Avatar
The T3/T4 clears it. But when i had a 16G6 i just put a silicon hose on the turbo before i put it in and it formed around it.
Old Apr 5, 2008 | 06:26 PM
  #36
MK3Design's Avatar
Yeah thats what I did, but I think I might get http://www.atpturbo.com/Merchant2/me...egory_Code=RUB
Old May 28, 2008 | 09:12 PM
  #37
lancerSE06's Avatar
alright i finally got my over sized pistons tonight. I'll be dropping them off tomorrow at the machine shop so i am really close to finishing this build.
Old May 30, 2008 | 04:26 PM
  #38
krnzzang84720's Avatar
sick setup, give us update after dude
Old Jul 12, 2008 | 10:27 AM
  #39
austenm's Avatar
quick question, how hard was it to convert to a returned fuel system? is it just a matter of running a fuel line and getting a second fitting on the fuel rail?
Old Jul 22, 2008 | 03:31 PM
  #40
lancerSE06's Avatar
I used the 02-03 fuel rail and just drilled a hole in the fuel pump holder and put a brass fitting on it and ran 5psi fuel line. UPDATE my wiseco pistons where sent to me with stock bore and i haven't got the new ones yet and i leave tomorrow for Basic training and AIT so i'll start working on it in january when i get back.
Old Jul 22, 2008 | 11:43 PM
  #41
smartidiot2122's Avatar
how long till the beast leaves its cage? or when is it drivable...?
Old Jul 23, 2008 | 12:30 PM
  #42
Complink's Avatar
are you in the army? what's your mos? great build btw. I just finished my turbo build and omg its crazy.
Old Sep 14, 2008 | 01:24 PM
  #43
lancerSE06's Avatar
National Guard my MOS is 63B.
Old Sep 14, 2008 | 03:48 PM
  #44
Demon_ni2's Avatar
so wheres the beast at? is it being drivin yet? whats the hp at!
Old Oct 10, 2008 | 03:07 PM
  #45
lancerSE06's Avatar
Its still in the shop. I graduate AIT the 18th of december then when i get home i just have to put it together.
TTP Engineering
Oct 29, 2009 10:48 PM
TTP Engineering
Sep 27, 2009 05:32 PM
Majuljo
May 31, 2007 08:52 PM
evonm4g63
17
Sep 24, 2005 02:42 PM
Typhoon Drifter
102
May 9, 2004 01:12 PM
