What to do for 06 fuel options
Old Mar 1, 2008 | 02:50 PM
MK3Design's Avatar
Ive been building my 16g kit by following along other similar threads. And now I am done! Or so I thought. I have Impreza 2.5 injectors (280cc, not much bigger from our 240cc, but they were free from my old car ), walbro 255lph, and a FMU.
But it turns out the 2006 models are returnless, so I cant use a FMU. I am all ready to install my kit, I just need to figure out this issue, budget is now down to a remaining $300..
My friend said it wouldnt be hard to make a return line so I could install the FMU, he didnt give much info on that though? Can it be done, if so what parts?
Thanks guys
Old Mar 1, 2008 | 02:57 PM
ambystom01's Avatar
Could buy the parts from an older lancer or go with an aftermarket piggyback ECU.
Old Mar 1, 2008 | 03:04 PM
MK3Design's Avatar
I don't have any experience with piggybacks, I'm sure I could install one, are they fairly easy to use? (and whats everyones favorite?)
Old Mar 1, 2008 | 03:09 PM
ambystom01's Avatar
If you don't know what you're doing, hire someone who does.
Old Mar 1, 2008 | 03:41 PM
lncrphish's Avatar
I was under the impresion that you had to use a piggy back if you used bigger injectors like wrx. im not sure if they are the same as impreza ones. What about ecu flash? I was going to use wrx injectors for my build but was told they were to big to use with just fmu.
Old Mar 1, 2008 | 03:46 PM
ambystom01's Avatar
If you use bigger injectors, you need a way to retune the fuel map.
Old Mar 3, 2008 | 05:00 PM
MK3Design's Avatar
Well, I just got a laptop. Has anyone tuned there turbo lancer with ECU Flash?
Old Mar 3, 2008 | 05:18 PM
drucea's Avatar
For a return system, I had this question too, go to a junk yard and get an 02-03 lancer intake manifold, fuel rail, return line, and fuel pump. Does anyone know if the 02-03 ecu has any part in this or does the fuel just return on it's own from pressure, or what?
Old Mar 3, 2008 | 07:24 PM
lancer2show's Avatar
i wonder if the gm maft works on the lancer.
Old Mar 3, 2008 | 09:35 PM
lancerSE06's Avatar
To make it a return fuel system all you need is the 02-03 fuel rail and reg. fuel line can't how i used and i used a copper 90. i also have a walbro 255 that i have wired to a toggle switch from the battery.
Old Mar 4, 2008 | 05:02 PM
MK3Design's Avatar
So would I be fine with my walbro 255, 280cc injectors and tune on ECU flash. My wastegate is 7.8psi btw
Complink
Lancer Engine Management / Tuning Forums
277
Jul 23, 2016 05:47 AM
t3lancer2003
Aug 11, 2008 04:35 AM
kungfugirl
40
Apr 19, 2008 04:24 PM
kungfugirl
Lancer Engine Tech
30
Jul 31, 2007 09:10 PM
Racer24x
Lancer Engine Tech
Apr 30, 2007 04:11 PM
