this is what happens when i get bored!
Old Sep 14, 2009 | 05:07 PM
  #211
JRR's Avatar
JRR
ok so most of you know i started the thread about the o2 housing. after much research and me going DUH!, i founfd that the evo 8/9 o2 housing is not campatible with my evo 3 turbo (thanks to the ///rre website!). although i did find out that i can get all the flanges for about 50 bux plus shipping.
with my original build i took my stock dp and cut/welded it ant about a 60 deg. angle and put on a 3 bolt 3" flange to make the o2 housing bolt up to my current exhaust.
reason im lookin so hard into this is that im lookin at the greddy ti-c exhaust and i dont want to have to cut anad weld such a nice piece of work to make it work with mine, that and the evo dp should open it up a bit more as in flow, i think?
now its a matter of getting the flanges and welding it up.
josh
Old Sep 14, 2009 | 08:29 PM
  #212
JRR's Avatar
JRR
so i "smoothed out my tabel a little more in the 1500-6000 rpm range and 80-90% load.
should i smooth it out a bit more around that?
josh
Old Sep 22, 2009 | 04:12 PM
  #213
JRR's Avatar
JRR
so in the pic below attached for #6 the speed adjusting screw, where is that sposed to be set at? i cant seem to find any information on it and it got bumped cuz my car likes to idle round 2k rpm. any thoughts?
Attached Thumbnails this is what happens when i get bored!-speed-adjusting-screw.jpg
Old Sep 22, 2009 | 07:36 PM
  #214
03lances's Avatar
Can you let your car run and then adjust it out? My guess is counter clockwise would begin to lower the idle back down.
Old Sep 22, 2009 | 08:38 PM
  #215
JRR's Avatar
JRR
thats what i though.
i work with r/c cars as a second job and most of the engines we use will have a setting like screw it all the way in and then back it out 2.5 turns or something will put it back to factory settings.
josh
Old Sep 23, 2009 | 07:26 PM
  #216
JRR's Avatar
JRR
ok so from pocket dyno on my ipod touch (free app by the way)....
263whp
13.75 1/4 mile
5.68 0-60
11.2 psi
stock internals
i will do some more tries at it and go from there to get a better idea of what im making.
josh
Old Sep 23, 2009 | 08:34 PM
  #217
03lances's Avatar
Hey thats pretty cool I wonder if they have anything like that for my storm... probably not
  #218
03lances's Avatar
have you tried the VDR virtual dyno simulator?
Old Sep 23, 2009 | 08:40 PM
  #219
JRR's Avatar
JRR
na not yet but i will try it now that i know about it.
Old Sep 23, 2009 | 08:41 PM
  #220
JRR's Avatar
JRR
o and btw thats stilll all on stock internals!
Old Sep 23, 2009 | 08:45 PM
  #221
03lances's Avatar
Ya it will be alot more accurate than the ipod I am sure and give you a nice graph here is the thread to download it, it is also free and pretty cool I think
Old Sep 23, 2009 | 08:47 PM
  #222
ianm12's Avatar
I spend a little money her eand there for custom work and it is more just for the fun!
Old Sep 25, 2009 | 09:35 PM
  #223
JRR's Avatar
JRR
hey i think i can but in not sure so this is why im asking...
first off will the evo tb work with our lancers and second is there any up/down side torunning it?
my idle adjuster screw is soout of wack its annoying. back it out (pull it up) and it idles higher, push it down it does the same thing. im idling at like 2grand and its really annoying as i stated earlier.
josh
Old Sep 25, 2009 | 11:49 PM
  #224
03lances's Avatar
You sure you dont have a vaccuum line off?
Old Sep 26, 2009 | 06:40 AM
  #225
JRR's Avatar
JRR
checked them, nothing off here. no holes or cracks either.
