The time has come to boost the lancer
Old Sep 20, 2008 | 09:55 PM
  #91
lncrphish's Avatar
Its a little bigger, but it will fit snug.
Old Feb 28, 2009 | 02:49 PM
  #92
lncrphish's Avatar
***update***
the car is running fine and everything is well @ 7psi. I did order one of the speedcorps manifold but just for the clean look. The one that i have know is a modded evo mani and it works fine but the drilled out holes are just not esthetically pleasing to my eyes.
I have also done a few other things to the car since last post. I have tinted the windows, smoked out side markers, and worn out my front tires.
Old Feb 28, 2009 | 05:35 PM
  #93
Demon_ni2's Avatar
worn out your front tires? shouldnt be spinning them to much!
mines running good to, and i just got a new set because mine had been bald for a WHILE, and new pads! lol safer on the street, and fast!
good to hear your cars is going good. get some more pictures soon!
Old Feb 28, 2009 | 06:03 PM
  #94
lncrphish's Avatar
Thanks^^I will put up some new pics when i get my new bumper on but for now here are some old ones.
Old Feb 28, 2009 | 06:45 PM
  #95
Demon_ni2's Avatar
oh you show off!
looks good
Old Feb 28, 2009 | 06:51 PM
  #96
link62's Avatar
looks good, so what bumper you getting?
what you used for the oil return and oil pan tap?
Old Feb 28, 2009 | 08:14 PM
  #97
Demon_ni2's Avatar
ya how did you do the oil return line?
mine was tig welded on with an aluminum fitting that was about the same size as a -8an line, and looks like a factory fitting on the pan.
Old Mar 1, 2009 | 08:56 AM
  #98
lncrphish's Avatar
I have the evo7 style front bumper waiting for paint. I had to get it cause i hit some animal on the road one night and its all cracked.
the oil return was crafted using brass fittings and polyurethane washers. the one in the picture is actually to big (long) so we made a smaller one.
Old Mar 1, 2009 | 12:39 PM
  #99
ThunderOZ's Avatar
If it's the VIS one like I have, the intercooler/pipes fit into it perfectly
Old Mar 1, 2009 | 01:04 PM
  #100
lncrphish's Avatar
sweet! it is.
Old Mar 1, 2009 | 01:05 PM
  #101
link62's Avatar
do you remember the sizes of the fittings you used by chance?
Old Mar 1, 2009 | 01:32 PM
  #102
ThunderOZ's Avatar
More pics
Old Mar 1, 2009 | 02:13 PM
  #103
lncrphish's Avatar
don't remember the size of the fittings but i used ones that fit the return hose. here is a better picture. I did change it to a 45 angle barb fitting because it did not work well sticking straight out.
Old Mar 1, 2009 | 02:29 PM
  #104
lncrphish's Avatar
new one from the bottom:
Old Mar 1, 2009 | 02:51 PM
  #105
ThunderOZ's Avatar
What fittings did you use for the water portion of the turbo?
