The time has come to boost the lancer
Old Sep 1, 2008 | 11:09 AM
  #76
ant_BLR's Avatar
Originally Posted by senate6268
A few people have gone the route of simply welding a 4G9x exhaust flange to a standard Evo turbo manifold. You need to weld them together all the way around and also do some weld work inside the runners since they don't match up that well on the end runners. Then you need to drill out the holes for the exhaust studs on the cylinder head.
so im guessing its no big project to get the evo manifold and get a lancer gasket then drill the new holes?
Old Sep 1, 2008 | 01:38 PM
  #77
drucea's Avatar
You should just pm all your questions, many of them are repetitive. Thanks
Old Sep 1, 2008 | 01:52 PM
  #78
MurphDurph's Avatar
Can you tell me details on the water connection like the location and which hose...that's really the only part I'm confused on now....so overall it took you what, 3 days install time? (minus the spacer setback)
Old Sep 1, 2008 | 05:03 PM
  #79
lncrphish's Avatar
I can email you pictures and instructions on how to connect the water lines just send me your e-ail address. over all time, lets see: started at 9am on sat. and worked until 5am. back again on sunday at 12 noon, and finished at 8pm.
But had 3 other friends working on things at the same time.
Old Sep 1, 2008 | 06:20 PM
  #80
lncrphish's Avatar
Video is up in "show and shine"
Old Sep 2, 2008 | 12:40 PM
  #81
ThunderOZ's Avatar
So no leaks or anything so far?
Old Sep 2, 2008 | 07:45 PM
  #82
lncrphish's Avatar
Do have an exhaust leak but i expected it since we needed another gasket for the other side of the spacer. we used rtv for the now until i can get another gasket. The service engine soon light did come on today during normal driving. trying not to boost untill i can fix the leak, then going to try to get a tune as soon as possible taking out the fmu and installing 330cc injectors.
Old Sep 2, 2008 | 08:17 PM
  #83
ThunderOZ's Avatar
using a fpr?
Old Sep 2, 2008 | 10:27 PM
  #84
TheShortBus's Avatar
sounds good man!
you pretty much got the exact same set up im running.
now just go get some wrx 440cc injectors
Old Sep 4, 2008 | 06:48 PM
  #85
Green_Bandit's Avatar
Which code are you throwing?
P0171 by chance?
Old Sep 4, 2008 | 07:57 PM
  #86
lncrphish's Avatar
Dont know. Have to take it n and see. waiting to get the exhaust leak fixed.
Old Sep 6, 2008 | 05:56 PM
  #87
ThunderOZ's Avatar
so when you take the fmu out are you going with an aftermarket fuel pressure regulator or what are you doing?
Old Sep 6, 2008 | 07:38 PM
  #88
lncrphish's Avatar
Going to put in 330cc injectors I procured from a member here and going to tune. probably ecuflash.
Old Sep 20, 2008 | 04:43 PM
  #89
lncrphish's Avatar
New addition: Wife got me a HKS Turbo Timer V1. It also gives you 0-60 time and 1/4 mile time. Going to put it in where the clock is in the dash.
Old Sep 20, 2008 | 09:42 PM
  #90
drucea's Avatar
Sweet. Does it pretty much fit the exact size of the clock?
