The time has come to boost the lancer
Old Mar 1, 2009 | 04:30 PM
  #106
lncrphish's Avatar
What do you mean? 2 brass t- fittings into the water lines at the \TB. Used clamps onto the turbo metal water pipes that came with the turbo.
Old Mar 1, 2009 | 05:20 PM
  #107
ThunderOZ's Avatar
Oh ok, see I don't have the water lines on my turbo...
Old Mar 11, 2009 | 11:44 AM
  #108
zulu989's Avatar
im guess this is what ill be doing with my turbo since i have the coolant lines attached
Old Mar 11, 2009 | 09:06 PM
  #109
Demon_ni2's Avatar
ya.. im kinda glad my turbo is oil cooled only.. i didnt want to mess with coolant lines also.. just to much stuff going everywhere already
Old Mar 11, 2009 | 09:07 PM
  #110
ThunderOZ's Avatar
Is it necessary to oil and water cool the 16g?
Old Mar 11, 2009 | 09:08 PM
  #111
ambystom01's Avatar
It's better for the turbo certainly.
Old Mar 11, 2009 | 09:16 PM
  #112
ThunderOZ's Avatar
I mean yea it's better but is it necessary at 7psi?
Old Mar 11, 2009 | 09:22 PM
  #113
ambystom01's Avatar
It's not necessary, if you can find the lines and hook them up without too much extra work, it might be worth doing. However, the engine might die before the turbo does so it's not a big deal by any means.
Old Mar 11, 2009 | 09:23 PM
  #114
Demon_ni2's Avatar
well.. even at 7psi.. if the turbo is setup for watercooling there are sections that will be certainly be to hot and u still risk damaging the turbo.. longevity is key with every turbo. the better cooled the longer they will run.
if your turbo has watercooling on it.. u need to watercool it, no point in not doing something easy.. and yes even at only 7psi it needs to be watercooled..
our water hoses are very easy to access.. no excuses for not setting it up right.
Old Aug 31, 2009 | 01:33 PM
  #115
lncrphish's Avatar
*****UPDATE******
One full year with turbo on the car and no problems...
Changed the oil every 3 months and going to take it off to check and clean everything.
here is a current picture. The stripe i added to hide a smuge in the paint on the fender. The fender will be re-painted soon.
Old Aug 31, 2009 | 03:18 PM
  #116
JRR's Avatar
JRR
i did on mine. it helps. but instead of "t'ing" it somewhere i just ran one line from the tb to the turbo and then one from the turbo to the tb. used 1g dsm lines. i can post picks if needed
josh
Old Aug 31, 2009 | 04:22 PM
  #117
link62's Avatar
josh
i like to see that can u post pics?
Old Aug 31, 2009 | 04:41 PM
  #118
JRR's Avatar
JRR
i will try to grab some tonite still, but idk by time i get done with work. ill for sure grab some tomorrow in the daylight
josh
Old Aug 31, 2009 | 04:42 PM
  #119
senate6268's Avatar
josh
Ummm.....
Wait, so the two tubes that are under the throttle body. You connected each one to each coolant fitting on the turbo? If this is the case then you've completely isolated the turbo and throttle body from the engine's coolant system. Or am I misunderstanding what you said?
Old Aug 31, 2009 | 04:46 PM
  #120
link62's Avatar
josh
cool also where did you pick up the 1g lines from by chance
