would this work???
Old Oct 17, 2008 | 08:45 AM
  #46
lancer2show's Avatar
im sure he meant from a roll. youll be suprised what a turbo lancer can keep up from a roll.
between 7-9psi you should be at least @ 200whp.
it usually goes by whp not how much boost your running till your motor starts messing up.
Old Oct 17, 2008 | 08:48 AM
  #47
it kinda feels like your first time....
turbo+coilovers+highway @80mph=sex
Old Oct 17, 2008 | 09:06 AM
  #48
evoguy69's Avatar
this is your best bet.get on ebay and find someone selling their complete turbo kit from an evo8 or 9 .youre looking at 200.00 or 300.00. these parts are so common you may be able to do even better than that.the other things you will NEED are a manual boost controller,upgraded injectors and someone to tune this beast.here is the 1 problem the header will have to be custom fabbed unless you can get online and search till you find something that will work.even a completely custom header should cost under 1500.00i dont see why you couldnt get everything installed and tuned for under 3 grand.good luck.after you do this you will need a lsd or some kind of locking diff.if not you will be just burning off 1 tire.as a side note i dont know how good your stock internals are but 10 psi is prob. the most you can safely go.your tuner will be able to get you set up right. good luck
Old Oct 17, 2008 | 09:08 AM
  #49
bcollinstex's Avatar
True, but RRM sells a turbo manifold ready to go for the 16g for about 400 bucks.
http://www.roadracemotorsports.com/s...roducts_id=389
Just saying that, you can save some more money.
Old Oct 17, 2008 | 09:25 AM
  #50
ambystom01's Avatar
The only way you're going to keep up with a lightly modified evo is if it's modified either incorrectly (BOV, intercooler, no tune) or in ways that have no bearing on power (ie. sway bars, rims).
Old Oct 17, 2008 | 09:39 AM
  #51
m3ta11ica12345's Avatar
just a regular kit from an 8 or 9 will fit my car? are there any modifications that ill need to do? i want to get new pistons and rods so i can run more psi. and i dont plan on getting a header. how much will it ocst for a tune?
Old Oct 17, 2008 | 09:41 AM
  #52
yeah this is my first time thats y im makin threads like crazy and using the search button a thousand times a minute
i really dont plan on keepin up with an evo i feel that expectation is unrealistic
Old Oct 17, 2008 | 09:42 AM
  #53
do the 8s and 9s use the 16g turbo?
Old Oct 17, 2008 | 09:44 AM
  #54
I suggest you search. There has been fitment issues retrofitting an evo 8/9 turbo setup to our engines. Search some of the buildups in this section for the details.
Also, tuning, depends on the tuner, stock ECU or piggy system. For dyno tuning it can be roughly 150 200 for a couple of pulls.
Sorry. That mani is for a EVO 3.
Old Oct 17, 2008 | 09:45 AM
  #55
ok sounds good to me. ill do some searching then.
Old Oct 17, 2008 | 09:47 AM
  #56
ok thats what i thought lol
Old Oct 17, 2008 | 07:33 PM
  #57
14b 16g 18g 20g will fit on the rrm manifold.
Old Oct 17, 2008 | 07:48 PM
  #58
doctorjon's Avatar
lol 14b and t25 are okay. Go with the 16G or atleast a gt28 turbo.
Old Oct 17, 2008 | 08:19 PM
  #59
^^ i agree. sometimes bigger is not always good for low boost unless your running internals. 16g, t28 is plenty on stock internals...you cant even max the turbo w/o a built a motor. hell you can barely max it w/ built internals.
Old Oct 17, 2008 | 09:13 PM
  #60
lilazn64's Avatar
There's alot of customizing to do, but if you have all the right tools, you can do this yourself. It took me 18 hours to drill, weld, grind, cut, shape, and manipulate things to make it fit properly. I did it all for 1800 including all the necessary gauges.
https://www.evolutionm.net/forums/sh...d.php?t=139735
