Safe to turn up boost after tune?
Old Apr 5, 2009 | 08:10 PM
cantcatchme96's Avatar
Registered User
good point, I'll see, boost controllers are expensive for decent ones
Old Apr 5, 2009 | 10:18 PM
Complink's Avatar
just don't go greater than 12.5:1 afr
Old Apr 5, 2009 | 11:49 PM
4g94T's Avatar
Complink: yes, stock internals
I'm using a hallman MBC and I haven't had any issues.
I think it was around $80-$90.
Old Apr 6, 2009 | 04:21 PM
asimpson719's Avatar
what about turning the boost down after you tune?
Old Apr 6, 2009 | 05:20 PM
ambystom01's Avatar
Sure but why?
Old Apr 6, 2009 | 05:34 PM
casper980's Avatar
sounds like your getting 1 psi of pressure drop from your turbo to the manifold, given thats where your boost gauge is taking its reading. It is very plausable that he has a 7 psi wastegate spring and only generates 6 psi at the IM, I would say its very acceptable. Evo owners don't notice it because we never run spring pressure.
Old Apr 6, 2009 | 06:02 PM
Originally Posted by ambystom01
Sure but why?
just wondering
like if you wanna race at say 15psi but you dont u wanna daily drive it so you turn it down to 8psi to drive and back up to 15 to race.
Old Apr 6, 2009 | 08:16 PM
Demon_ni2's Avatar
you can do that but you need another map that you can reflash the ecu with.. or a standalone that will compinsate for the boost differences.
(so laptop in the car to change maps is the easy way to do that)
Old Apr 6, 2009 | 08:55 PM
ambystom01's Avatar
Exactly, if you went from 10 to 9, you'd run a bit rich but it wouldn't be a big deal. If you went from 15 to 8, it would run very rich.
Old May 2, 2009 | 10:33 PM
Chameleonzero's Avatar
Unless you have upgraded pistons and rods then I would just keep it at 6 or 7psi...Better to be safe then sorry
Old May 3, 2009 | 09:11 AM
senate6268's Avatar
Not necessarily the case. You scan safely run 10-12psi as long as you have a proper tune. I've been running over 10psi for 2 years now on two different turbo setups. People have popped their motors on 6 or 7psi with no/bad tuning, so you're better safe than sorry point is moot. On our motors, the pistons/rods do not take well to bad tuning and boost.
Old May 3, 2009 | 06:43 PM
Demon_ni2's Avatar
i second this 100%
u can run 10-12psi on our motors safely with a good tune.. but if you tuned for say 7psi.. stick to that! or get retuned for higher boost if u want to run more..
anyhting over 9psi i do 100% suggest a decomp gasket and arp headstuds, because lifting the head is very possible.. and upgradeing them is EASY!!!!
adamkmay
Aug 10, 2015 02:09 AM
formerSTIowner
Nov 7, 2013 05:29 AM
Chukee_R
17
Jul 2, 2007 02:03 PM
IntegxX
10
Jul 27, 2006 01:07 PM
