Oil Lines to 16G turbo
I don't see a thread regarding on how to connect oil lines, 03 lancer showed me his set up, but on my turbo I have 3 oil connections and I do not know where they go here are some pics to show you what im talking about!
my td05hr 16G 9.8T
my td05hr 16G 9.8T
Where do you see 3 oil connections? When the turbo is connected to the manifold, the top hole is the oil feed, the bottom with that gasket that you'll need to replace is the oil return/drain. The silver pipes on the front and back are water lines.
Here is a diagram for the oil and coolant lines
This Is the type of fitting you need for the oil return but for the 16g, it will fit a 5/8" hose 1 foot long that will attach to a 5/8" hose barb you can get at home depot that will go into your oil pan after you have tapped it.
o that and the oil line that you hacve on there now with that bracket, yur gonna have to cut that off and a little on the marking plate there for the turbo to clear the water pipe that is rite there as well as an fyi.
josh
josh
not true. that all depends on the turbomanifold you use and how the turbo is positioned.
ok so that tube from the bracket that is circled where does that connect to? or do I just take it off? from my understanding that is the oil return or feed?
That tube will not be used that is the stock oil feed line. I used the banjo bolt from it and just got the banjo fitting with the -4an end
ok I see that like you said before, How did you do your oil return system? thats the last thing I need to know then I understand how to set up the turbo system, and how many millimeters was your 4an banjo fitting? im going to buy one this week
steven121
Lancer Aftermarket Forced Induction Tech
1720
Mar 11, 2021 08:41 AM
FS[South]: 2003 Mitsubishi Lancer Evo 8 RED "TX"
steven121
For Sale - Cars For Sale
Jun 27, 2014 07:17 PM
steven121
Apr 20, 2010 09:32 PM
steven121
20
Mar 24, 2010 11:41 AM
