Starting a turbo build on my 04 lancer
Old Jan 24, 2010 | 07:49 PM
  #61
crf inc.'s Avatar
Originally Posted by JRR
well i got all the parts now. i just need a couple pieces of pipe, to bend it, snd then weld it together for my wastegate and ill be ready to go. i plan on doing this in acouple of weeks so it will be soon!
josh
damn it josh!!! just send him the parts already!!! hahaha no time for all the fine print!! hahaha just kiddin.. im kinda krunk status.. juist ignore me!
Old Jan 24, 2010 | 08:11 PM
  #62
JRR's Avatar
JRR
well i pretty much have most of it ready to go. just need the final and most important ones.... like mani and turbo........lol
josh
Old Jan 24, 2010 | 09:29 PM
  #63
Wewocadet's Avatar
josh
Hahaha you don't need that stuff
Old Jan 24, 2010 | 09:31 PM
  #64
Wewocadet's Avatar
Hahaha nice I'm right behind you
Old Jan 24, 2010 | 09:37 PM
  #65
JRR's Avatar
JRR
ooo i know yur feelin. i went threw 3 turbos before i finally decided to go with what i did, and i would send you everything, but i still need it to get around and specially now that im going back to school which is about 25miles away IN WISCONSIN IN WINTER... lol
but tomorrow im going to stop down at the local welding shop and see if they have any scrpa laying around that i can pick up cheap for what i need to finish everything. hopefully scott from ams and chele get back to me soon on what materials wew used on both the manifold and wastegate flanges so i know what metal to acutally buy for the best weld then.
josh
Old Jan 24, 2010 | 10:28 PM
  #66
crf inc.'s Avatar
hahaha i know what you mean/// got to get all the little b.s. done before doin shyte... by this point im really drunks... just ignore me.. im rico suaveeeee.. hahahahhahahaha
Old Jan 24, 2010 | 10:29 PM
  #67
Wewocadet's Avatar
Hahahahahahahahaha
Old Jan 24, 2010 | 10:30 PM
  #68
crf inc.'s Avatar
daaaaaaaaaaaaaaaaaaaaaammmmmmmmmmmmmmnnnnnnnnnnnnn nnnnn sonnnnnnnnnnnnnnnnnnnnnnnnnnnnnnn....... if fu*kin drunk on a sunnnnnndayyyyyyyyyyyyyyyyyyyyyyy....bbbbbaaaaaaaa aaaaaaaaahhhaaaaaaaaaahhhhhhhhaaaaaaaaaaaaaaaaaaaa aahhhhhhhaaaaaaaaaaaaaaaaaahhhhhhaaaaaaaaaaaaaaaaa aaaa
  #69
Wewocadet's Avatar
josh
Ok no worries. End of the month would be perfect for me anyways. But my grandpa did that through snow sleet and rain barefoot lol. Or so he says
Old Jan 24, 2010 | 10:34 PM
  #70
crf inc.'s Avatar
first n fifffteeeenth biiiotch
Old Jan 25, 2010 | 08:18 AM
  #71
japordie's Avatar
I think we should start a sticky thread on turbo-ing a lancer, so that everyone can know what to do. Other than the 16g set there are very few other routes to take, hence were all close in the money bracket, (of course not all of us). Of coures people would still have Q's even if we posted it picture by picture, but it would still explain alot! just to through it out there
Old Jan 25, 2010 | 01:06 PM
  #72
steven121's Avatar
lol thats actually a good ideer
Old Jan 25, 2010 | 03:36 PM
  #73
JRR's Avatar
JRR
somebody already stared a thread but idk what happened to it and it wasnt stickied either.
josh
Old Jan 25, 2010 | 07:18 PM
  #74
Wewocadet's Avatar
Hey guys I need your help again. I emailed a shop if they could dyno/tune my car with the fifth injector setup and thos is what he said
I can tune your vehicle, but I am not a fan of supplemental injectors. I
can reflash the stock ECU to handle part of your needs but the problem
with the Lancer ECU is it doesn't properly recognize when the car is
actually in boost. What ends up happening is I have to add a ton of fuel
to the upper load regions that normally cover higher load (but still in
vacuum). The car acts fine under higher boost levels (such as when you are
wide open throttle) but it makes the car excessively rich when you are
steady state cruising or mildly accelerating at manifold pressures between
0 vacuum and roughly 1/2 of your peak boost level.
This doesn't sound great. I want my car running perfect the whole time jus not at some points
Old Jan 25, 2010 | 07:38 PM
  #75
JRR's Avatar
JRR
with the 5th injector, what he says isnt entirely true because i have successfully done it without flashing any part of the acutal ecu when having this setup. i will try to post a pick of what i mean but im on another computer right now and i gotta remember which one it is on that i tuned it last with.
the base map that came on the 5th injector controller from road race was super rich and was actually adding a ton of fuel even before i was at boost. my friend and i got it tuned really well on the back country roads where i grew up at one night, and then could consistently add fuel to the car without making it hesitate due to too much or too little fuel.
this is also why its a necessity to get a wideband gauge so you can see what is actually going on with the air/fuel mixture.
josh
