Starting a turbo build on my 04 lancer
Ok guys I was checking out under the hood for the turbo and figuring everything out. Thanks to Carl the ic piping goes where my washer fluid is so that's gone. I'll prob relocate it later but I think I found what everyone was talking about....that famous 04-06 tranny/clutch cylinder. The only part that looks like it might be in the way is a block on the bottom left below my headers. Here is a pic of what I'm talking about
But this little cylinder part looks like what everyone is talking about. It to the right of the headers just above motor mount. *
So the little cylinder on the right is this one in the way? If so I don't see anywhere I can move iT. Any suggestions or is the noob way outta the ball park here lol
josh
How close is the turbo to the slave cylinder when it's mounted? Would you be able to use a hump hose as a coupler or is there not enough room?
To the contrary, it is actually better to swap from the 02-03 style to the 04-06 style due to the ability to swap out individual components - TOB, slave cylinder, fork, etc. You would think that since that manifold was made to suit the 4G94 engine with a 16G6 turbo that clearance would not be an issue. Hmm...
i got pics on my fone, i just gotta find my cable to get them off
josh
with spacers you would have to bring it out about 2" which then in turn with an evo turbo you would be thru the rad support. for this i would get a custom 1/2 gen eclpise mani done and then mount the turbo like the evo going towards the drivers side, not to the passenger side like the eclipse. with this the turbo then would "curl" out and away from the block unlike if you mount it towards he passenger side it will "curl" in on the eclipses.
UPDATE!!
I have a dohc conversion for my lancer
I have a custom turbo setup with a hybrid t25/t28 (so i was told)
rrm intercooler and piping
wrx injectors
evo 8 bov
up/down pipe setup
header
tial wastegate
stage 3 plus clutch
aluminum flywheel
lightweight pulley
I have more coming like:
walbro
slim mount fans
8.8 low comp pistons
pauter rods
standalone
arp head studs
short shifter
gauges an pods
and probably a few more things i forgot. but so far my build is looking good :-)
wrx injectors
evo 8 bov
up/down pipe setup
header
tial wastegate
stage 3 plus clutch
aluminum flywheel
lightweight pulley
walbro
slim mount fans
pauter rods
standalone
arp head studs
short shifter
gauges an pods
anyone here know about the 4g93t DOHC swap? im trying to find a half moon seal and 4 spark plug seals for it. i got these part numbers i just want to double check if anyone knows about this
MD186784 Rocker Cover
MD186785 x 4 Spark Plug
MD050536 Half Moon
MD153103 x 2 Cam Seals
MD184946 Rubber Plug (intake cam)
MD050536 Half Moon
