Misfire at higher boost
Old Mar 30, 2010 | 08:11 PM
4g94T's Avatar
I was doing a few runs today and my car kept misfiring at higher boost levels
and it was perfectly fine when I lowered the boost.
Im currently using NGK BKR7EIX plugs, they are one step colder and gapped to 0.32"
Should I go another step colder with a smaller gap?
I read in the evo forums that you should go one step colder for every 100hp gain.
Any suggestions?
Old Mar 30, 2010 | 08:12 PM
JRR's Avatar
JRR
7's are fine but loose the iridiums. i use standard ngk vpowers at 15psi on mine. and i belive that 8's would be "too cold" if you know what i mean.
Old Mar 30, 2010 | 08:45 PM
senate6268's Avatar
+1. Don't go any colder than BKR7E and move away from the iridium plugs. I run NGK copper plugs in my motors.
Old Mar 30, 2010 | 08:49 PM
4g94T's Avatar
so the BKR7E plugs will be okay with 300+ whp?
Old Mar 31, 2010 | 03:20 PM
4g94T's Avatar
searched around and these plugs seem to be popular with the turbo community.
unfortunately these are all special order so I cant give them a try until tomorrow.
ordered 2 sets since they need to replaced more often.
Old Apr 27, 2010 | 09:03 PM
4g94T's Avatar
Does anyone know of any spark plug tool that can gap lower than .025"?
Old Apr 27, 2010 | 09:22 PM
link62's Avatar
found this online http://www.restockit.com/Spark-Plug-...filiateprogram
Old Apr 27, 2010 | 10:01 PM
4g94T's Avatar
It looks like it only goes down to .010" because of the gauge.
The lowest I've seen is .025" and my car misfires with that still
Old Apr 28, 2010 | 10:20 AM
Demon_ni2's Avatar
hrmm.. ever thought that our coilpacks just dont supply enough spark to begin with?
i didnt have any misfire issues when i was at 16 or 20psi on 93
and that was with the bkr7e plugs also..
Old Apr 28, 2010 | 03:37 PM
4g94T's Avatar
maybe i need to replace my coils / wires...
i'll have to check them out
Old Apr 28, 2010 | 05:12 PM
senate6268's Avatar
You might want to look into switching up to a DSM ignitor & coil for a better/more reliable spark.
Old Apr 28, 2010 | 05:45 PM
Demon_ni2's Avatar
MSD can hook u up.
Old Apr 28, 2010 | 06:49 PM
senate6268's Avatar
Originally Posted by Demon_ni2
MSD can hook u up.
You can use MSD coils if you want, but you'll still need the DSM ignitor to run a wasted spark setup. Your best bet is to run a setup like this:
https://www.evolutionm.net/forums/ev...stock-ecu.html
It's inexpensive and is good up to around 600whp. The coils shown are better than a stock DSM coil, but a stock DSM is still way better than the coil pack setup on the 4G94.
Old Apr 28, 2010 | 09:08 PM
4g94T's Avatar
I'll have to look into that, thanks senate.
BTW I checked my coils / wires resistance and they are still within spec.
I guess I just reached their limit.
Looks like I'll be replacing plugs every 1k miles until I swap out the ignition
kyoo
Jun 25, 2016 12:10 PM
Jonesey I7
12
Jul 26, 2011 01:30 PM
kouzman
20
Jul 13, 2008 08:02 AM
gvr4737
May 15, 2008 10:18 AM
Evo8you2007
Mar 7, 2008 02:19 PM
