Rad Fan Help
Old Apr 23, 2011 | 12:08 PM
burner67's Avatar
Rad Fan Help
so i installed 2 new slim fans and they never come on and i cant get them to come on via evoscan either. any ideas?
Old Apr 23, 2011 | 03:32 PM
senate6268's Avatar
Can you provide more info. How did you wire them up? Did you test out the fans on a 12V source before install to verify they work? Is the fan controller still installed. Is it functional?
Old Apr 23, 2011 | 03:42 PM
milford's Avatar
did keep the stock relay when you did the new fans?
Old Apr 23, 2011 | 05:07 PM
burner67's Avatar
I tested them and made sure they work. I cut the fan connectors off the stock fans and connected them to the new fans. The fan control box is still there. Fuse #2 is fine. It makes no sense
Old Apr 24, 2011 | 03:32 PM
burner67's Avatar
help please bump lancer gonna explode
Old Apr 24, 2011 | 04:00 PM
03lances's Avatar
Try reconnecting the stock fans just to see if they will come on. If they do then right there tells you there is no problem with the cars end. If they dont then turn on the a/c, with a properly working system this turns on both fans right away and you can test for power right at the plug. If there is no power and the fuse is good then my guess is that would point to the fan controller itself.
Old Apr 24, 2011 | 04:45 PM
Green_Bandit's Avatar
How can you check the #2 fuse? Its not a traditional fuse and just a red box.
To the user, your fan relay may be bad. Its a common thing across the lancer platform (Evo, Ralliart, OZ). If your fans arent coming on that may be a possible issue
Old Apr 24, 2011 | 07:12 PM
burner67's Avatar
the #2 fuse has a little metal strip on top u can see if its still good or not. at least on my car its like that.
anyways i bypassed the module and it worked so I need a new control module for the radiator fan if anyone has a used one let me know
Old May 6, 2011 | 02:00 PM
burner67's Avatar
i bought a new fan control module and the fans still dont seem to come on. tho they do come on when i turn on the ac but still nothing at idle. any ideas would be appreciated. i was thinking that maybe its the coolant temp sensor?
let me know what you guys think thanks!
Old May 6, 2011 | 05:30 PM
jakermeister's Avatar
Turn your AC on and see if they work LOL My fans only work with the AC on
Old May 6, 2011 | 06:44 PM
burner67's Avatar
Dude I just said they work with the ac on :-)
Old May 6, 2011 | 06:53 PM
Hmm..new fcm, fans work, and fuse is ok. Are you starting to overheat?
Old May 6, 2011 | 07:51 PM
LOL Didn't read the whole post. I don't overheat with mine. If you need them on you could always hard wire them?
Old May 6, 2011 | 08:39 PM
burner67's Avatar
No overheating but it I remember I used to idle and the would come on every minute or so and they don't anymore..
Old May 6, 2011 | 09:30 PM
burner67's Avatar
could it be some temperature sensor? or something thats supposed to kick the fans on when the engine reaches a certain temp?
