My 05 lancer turboed lancer thread...never thought it would happen
Old Aug 18, 2011 | 04:01 PM
  #361
slatermvp's Avatar
did anyone take any pics when they were making the cable to log AFR from the AEM gauge??
I'm doing mine now and it doesn't feel to sturdy with the pins it came with that go into the female db-9
Old Aug 18, 2011 | 04:34 PM
  #362
slatermvp's Avatar
anybody wanna make me a cable?? I'll pay.
Old Aug 19, 2011 | 06:17 AM
  #363
Green_Bandit's Avatar
I've read to use hot glue to keep them in there
Old Aug 19, 2011 | 06:23 AM
  #364
slatermvp's Avatar
One of the stupid things got stuck so now I have to go buy another female DB-9 connection.
Old Aug 19, 2011 | 01:35 PM
  #365
HornstarBU's Avatar
I took a couple cables from the bin at work. Originally ups monitoring cables for the battery backups in the data center, but long outdated now. Well, I just lopped one end off, stripped all the wires, and used a multimeter and resistance to find which was which...then soldered them to the monitoring cable on the arm and the same ground cables as the arm and other gauges.
Old Aug 20, 2011 | 02:53 AM
  #366
ryancb's Avatar
Slater, ill post a pic tomorrow of what im doing i think you will like it, no splicing/soldering. For now sleep we just got the motor finished a about an hr ago.
Old Aug 20, 2011 | 04:53 AM
  #367
slatermvp's Avatar
pics please.
Old Aug 20, 2011 | 02:19 PM
  #368
ryancb's Avatar
Man i was dead tired last night but these are what I am using.
http://www.easyadapters.com/proddeta...?prod=FDB9-TB5
Old Aug 20, 2011 | 06:45 PM
  #369
slatermvp's Avatar
that looks pretty good actually
Old Aug 21, 2011 | 10:06 AM
  #370
slatermvp's Avatar
can someone answer this stupid question please:
more fuel = more timing
less fuel = less timing
is this correct??
Old Aug 21, 2011 | 10:57 AM
  #371
dee242's Avatar
Originally Posted by jrr
i beg the differ. He's sucha huge sellout. He can drive yes but he cant rally. 2 best parts about the video is the person kicking him in the face and the end when it was over...
+1
Old Aug 21, 2011 | 11:04 AM
  #372
03lances's Avatar
is this correct??
Not sure what you mean. If you richen the mixture yes you can run a little more timing since the fuel is cooling the charge more. Go too rich though and you will start to lose power
Old Aug 21, 2011 | 11:27 AM
  #373
slatermvp's Avatar
say I take away some fuel in certain load areas then the timing will need to come down as well correct. or when I richen it when in boost timing must be advanced then right?
Old Aug 21, 2011 | 12:17 PM
  #374
HornstarBU's Avatar
Sort of...but not quite so dramatic as you are thinking maybe.
If you set your AFR's close, then set timing and then adjust AFR if it needs it, you will be okay. Where are you talking, WOT? or cruise?
Old Aug 21, 2011 | 06:45 PM
  #375
slatermvp's Avatar
cruise, trying to get better gas mileage. It's running really rich since I switched to open loop a couple of days ago.
