My 05 lancer turboed lancer thread...never thought it would happen
Old Jan 24, 2012 | 09:55 PM
  #511
03lances's Avatar
Pretty sure I bought this exact one, even seems the price has dropped a little. It cheap for sure but has been working just awesome for me. I imagine if you hit something installing it your chances of putting a hole in it is probably a little higher then higher end one but hell for 1/3 the price I took the gamble. Here is some pics of stock vs evo 5 one I have
http://www.ebay.com/itm/1998-1999-Mi...sories&vxp=mtr
Old Jan 25, 2012 | 08:46 AM
  #512
slatermvp's Avatar
I ended up the evo 8 radiator that comes with fans. Couldn't pass up on the price and the fans are a higher flowing then the ones I have.
Old Jan 25, 2012 | 08:48 AM
  #513
slatermvp's Avatar
Originally Posted by 02-Lancer-Es
On the smoking when warming up sounds like valve seals / valve guides . Maybe even warn rings ! Does it also smoke after an oil change ?
It doesn't smoke after an oil change, just when warming up. Once I start driving its good. When the car gets to temp and just idling without driving it, it still smokes but little bit not alot. The car does have 166K on it.
Old Jan 25, 2012 | 09:52 AM
  #514
03lances's Avatar
Im betting your valve seals then like 02 lancer stated. Mitsus are notorius for the valve seals going bad around 150k+
Old Jan 25, 2012 | 10:17 AM
  #515
Green_Bandit's Avatar
About your tranny cooler how about just mounting it in the bay and attach a powered fan.
Old Jan 25, 2012 | 08:19 PM
  #516
slatermvp's Avatar
I'm gonna install it in front of the radiator. It's not a big one and it should be fine there. I texted Mitsukid and he said thats where he has his.
Old Jan 25, 2012 | 08:24 PM
  #517
slatermvp's Avatar
Since I have to do the tranny oil cooler I was thinking of changing the tranny fluid. Any recommendations on what kind of oil to use??
Old Jan 25, 2012 | 08:33 PM
  #518
02-Lancer-Es's Avatar
Ehh Better flow behind a bumper duct as air does not have to go threw anything else like intercooler , condenser and radiator .
Old Jan 25, 2012 | 08:35 PM
  #519
slatermvp's Avatar
gotcha.
What are you using for tranny oil??
Old Jan 25, 2012 | 08:38 PM
  #520
Oem done every 15k miles
Never ever had an issue and i drive my car really hard , hot lapping it at the track and hill country fun
I also take mine to 6800 Rpm
Old Jan 28, 2012 | 06:27 PM
  #521
slatermvp's Avatar
got some stuff fixed today that I had been putting off but couldn't anymore. Last night on the highway I was that damn slow car in the slow lane going 40 MPH. My driver's side axle broke. It had started clicking when turning but not too serious, well last night on the way back the axle completely went. When I took it off today, I found the inner part of the axles is what had broken.
Good thing that came out of these but I know in another thread there had been discussion of if whether the axles were interchangeable between the autos and the manuals and well I used a manual axle that I bought off ebay awhile back so they are interchangeable.
Changed the brake pads while I was at it and fixed some of the plastic below.
Anyone know where I can pick up a whole set of the wheel well plastic and all the plastics pieces under the car??
Old Jan 28, 2012 | 06:28 PM
  #522
slatermvp's Avatar
Sorry but do you get it from the dealership or are different types of oils for the tranny? I have never changed mine because before I used to work on my car the guys at Midas told me I didn't have to do that until about the mileage I'm at which is 166K.
Old Jan 28, 2012 | 10:18 PM
  #523
JRR's Avatar
JRR
as long as the fluid meets/exceeds the diamond sp whatever they are on now you are fine for trans fluid. i usually change my fluid in the trans and rear diff bout every 20-25k depending on how hard im diving it. if you have never changed it that filter is junk and not filtering anything by this point.
josh
Old Jan 28, 2012 | 11:36 PM
  #524
03lances's Avatar
You are lucky my friend. I recently had to go and tow 2 of my friends cars in the same night. Both broke there axles and both toasted their tranny because of it.
Old Jan 29, 2012 | 12:28 AM
  #525
I go to the dealer and pick up 8 quarts of the Oem fluid !
Your supposed to change it every 30k but since i drive it hard i change it every 15k
