My 05 lancer turboed lancer thread...never thought it would happen
Got my car back with deyemme motor mounts installed. I get a massage every time I sit in the car and its idling! I love it. Just needs an alignment tomorrow, need to raise the idle a lill bit and then it should be good to go.
Don't have to worry about leaks or any maintenance issues!!
where is everyone getting stainless steel brake lines from? RRM's autocrossing lines don't look like stainless steel ones. Everything I am able to find is not for Evos.
oh ok but they are stainless steel thought right? On the website it looks like they are covered in plastic but do not look like they are stainless steel and it doesn't say it on their site either.
Alright, bought an OMNI 4 bar map sensor. Just want to double check, this is all I need to go SD. Everyone has solved alot of idle and other annoying issues by going SD so I'm looking to do the same.
1. Do I need to change the Intake tube? If not what did you guys use to plug any holes?
2. Do I need to change to a different BOV? I have the evo 9 metal BOV right now.
I'm looking to bring the lancer back this spring. I haven't wrenched since about the last time I posted in this thread so please be patient as I'm a little rusty.
No u dont have to change bov or intake tube..you can buy a plug for the intake tube. www.lancershop.com has the plugs for the intake tube. The bov can stay like it is.
Does anyone have mirageman's information. I am going to be going disc in the back. I need to change the brakes in the back because the car has been sitting for so long but I want to just change over to discs while I'm doing that.
Any help I would really appreciate.
Thanks
Thanks
Thanks
Thanks
Slater,
How did the SD conversion go? I was thinking about going SD soon but since we have a returnless fuel system I was wondering if the start up was a issue during the winter. The return fuel system kind of warms up the fuel as it goes thru the engine bay and back into the tank. I bought a AIT sensor just in case I want to go that route but wanted some input from a 04+ lancer.
Slater,
