My 05 lancer turboed lancer thread...never thought it would happen
Old May 28, 2012 | 04:26 PM
  #616
slatermvp's Avatar
thats what I was thinking. While driving back home the voltage was reading 14.9 to 15.0, occassionally 15.1. While at a light it would be at 14.6 to 14.8.
How hard is it to change the regulator? I don't want to drive around, cuz it will fry my battery from the higher voltage.
Old May 29, 2012 | 06:58 PM
  #617
JRR's Avatar
JRR
change the alternator......its an internal regulator so its the whole unit.....
Old May 29, 2012 | 08:34 PM
  #618
slatermvp's Avatar
Oh ok. I thought it might be one of the external ones. Good thing I have another altenator laying around, imma swap it out on Thursday.
Old May 29, 2012 | 08:42 PM
  #619
JRR's Avatar
JRR
unless you have an older ford truck, riding lawn mower, or a tractor for the most part..... you will always have an internal regulator
Old May 30, 2012 | 09:28 AM
  #620
slatermvp's Avatar
Thanks for letting me know. Learn something everyday.
Old May 30, 2012 | 10:06 AM
  #621
JRR's Avatar
JRR
no problem. about the only thing that will give you a headache like it did with mine is the bottom bolt that holds it in. that was a real pain to get out.....
Old May 31, 2012 | 09:16 AM
  #622
slatermvp's Avatar
how did you get it off?? ****ing thing won't budge!!!!
Old May 31, 2012 | 11:20 AM
  #623
Green_Bandit's Avatar
Won't loosen or come out?
Old May 31, 2012 | 12:45 PM
  #624
slatermvp's Avatar
come out...I can move the radiator up and down. I was able to take the nut off but the screw won't come out. I tried tapping it with a hammer and now I have to go the junkyard on saturday to get one off of a mirage to put in when this one decides to come out.
Old May 31, 2012 | 04:29 PM
  #625
JRR's Avatar
JRR
impact and a lot of blaster.....
Old Jun 1, 2012 | 07:39 AM
  #626
slatermvp's Avatar
damn it, I left it soaking last night in wd 40. When I get home from work today I'm going to hit it again with wd 40 and hope it loosens up.
Old Jun 1, 2012 | 05:00 PM
  #627
JRR's Avatar
JRR
use a better penetrating catalyst than wd40. that should help.....
Old Jun 1, 2012 | 06:01 PM
  #628
03lances's Avatar
I like PB blaster myself, tri flow works good as well or "freeze it" penetration spray is great if its rusty
Old Jun 9, 2012 | 01:52 PM
  #629
slatermvp's Avatar
thanks for the suggestions guys, wd40 didn't do smack. Liquid Wrench did the trick. Altenator is replaced as well as rotors and pads.
Bad thing is I don't have my labtop so I can't continue tuning till Monday.
Old Jul 28, 2012 | 10:39 PM
  #630
slatermvp's Avatar
looking at installing the turbo xs boost controller, now i know how the lines go but I'm having a hard time figuring out how to mount it. I was going to mount it with a zip tie but the thing is the whole body turns to turn the boost up or down. Just looking for suggestions on how to mount it although I won't really be turning the boost up or down constamtly.
