My 05 lancer turboed lancer thread...never thought it would happen
Old Apr 13, 2012 | 06:14 PM
  #586
slatermvp's Avatar
Originally Posted by HornstarBU
Check your alternator wire? Maybe even test the alternator? Is it only when the heat is on, or when the A/C is one as well?
Also, millage, fill up tank, zero out trip meter, drive drive drive, fill up and divide trip meter by how much gas you put in, and that's your millage.
Don't top it off and reset the trip meter everytime you fill up, that way every fillup you get to see the MPG
I haven't tried it with the A/C on but it only happens with the heat on at the moment.
Old Apr 16, 2012 | 10:43 AM
  #587
slatermvp's Avatar
It does it with A/C on as well.
Old May 10, 2012 | 07:11 AM
  #588
slatermvp's Avatar
We I installed the oil pressure sender the other day. The only thing I have to do is hook up the wires from the sender to the gauge but before I do that I need to get the bracket for the radio relocation.
Does anyone have a different location for their oil pressure sender? That is the only place I could really find to put it in without the line hitting the axle.
Old May 10, 2012 | 07:13 AM
  #589
slatermvp's Avatar
I'm not very good at reading spark plugs so if someone could try to tell me what is going on with them, I would appreciate that. The spark plugs are in order from left to right if you were facing the engine.
Old May 10, 2012 | 07:18 AM
  #590
03lances's Avatar
From where Im sitting they look perfectly fine as far as condition. If it was running lean they would all be a lighter color and if rich then they would look darker than that.
Old May 10, 2012 | 07:26 AM
  #591
slatermvp's Avatar
sweet thanks. I'm having an issue with knock in the 70 ld btn 3k and 3.5k that just started happening so I thought it was the spark plugs. Its only like 2 counts of knock but still knock.
Old May 10, 2012 | 08:55 AM
  #592
Green_Bandit's Avatar
What do you have them gapped at? I had mine months ago about. 40 and got misfires under high load read the latest stuff from 03L's pages brought it down to 20...perfect.
Old May 10, 2012 | 09:14 AM
  #593
slatermvp's Avatar
The ones I just installed where I did at .30. The knock was around 70 load.
Old May 10, 2012 | 10:49 AM
  #594
RoadSpike's Avatar
70 load is just about the place where the computer does the EGR work. There is an EGR advancement table which i recommend cleaning out to 0's. Even if the car was to knock at that load level damage would be non existent unless it was crazy severe to the point of clearly audible knocking.
Most of the time in the evo rom I'd simply ignore that area out since it would occur for me even with 120 octane fuel haha! It seems that its just a sensitive area probably induced by some vibration in the motor. As you bolt things to the car you change the engines harmonic point and as the engine gets older it will just make more noise from looser parts.
Old May 10, 2012 | 11:48 AM
  #595
slatermvp's Avatar
Thats what I thought. I had changed the timing in that area down by about 3 degrees and still getting the same numbers.
Old May 10, 2012 | 01:28 PM
  #596
RoadSpike's Avatar
I'd just bring it back to normal and have the knock table adjusted to filter that area out.
Old May 10, 2012 | 03:36 PM
  #597
slatermvp's Avatar
alright will do.
Old May 10, 2012 | 03:37 PM
  #598
slatermvp's Avatar
any alternate locations for the sender? I kinda don't like it there for some reason.
Old May 10, 2012 | 05:01 PM
  #599
Why not just on the oil sandwich?
Old May 10, 2012 | 06:49 PM
  #600
jakermeister's Avatar
Mine is on the sandwich Its on the back part near the axle and still has a little room.
