turbo in lancer?
Old Feb 3, 2004 | 08:29 PM
timbo4656's Avatar
turbo in lancer?
is there any1 who has put in a turbo charger in their lancer?if spo what r the numbers? if not is there even a turbo chrger out there for lancers yet?(not the evo) also if i do put turbo in my lancer how much hp will i gain?
sry for the noobish post
Old Feb 3, 2004 | 09:37 PM
GSR97's Avatar
guys, i am planning to put this garett td04 to my 4g92 engine. is it really necessary to change pistons before putting up a turbo?
Old Feb 3, 2004 | 09:42 PM
bahamut's Avatar
timbo4656,
do a search . . . there are enough of them on the board.
Is that equal to the Mitsu designed 14b turbo?
All conrods in the G9x series are weak. You'll blow them before the pistons and headgasket.
Just need tuning and fuel for under 10 psi or so.
Old Feb 3, 2004 | 09:43 PM
liquidlancer's Avatar
www.roadracemotorsports.com
Old Feb 4, 2004 | 01:17 AM
eldanoloco's Avatar
I believe not, the TD04 is actually just the housing of the turbo, the 14B is TD05. For instance the 16G is the same housing as the 14B, just different internals. At least thats what was explained to me.
Old Feb 4, 2004 | 11:34 PM
ski10804life's Avatar
are you guys talkint baout putting these turbos in your lancer ralliart's?
Old Feb 4, 2004 | 11:43 PM
OZevoVII's Avatar
you are def. in the wrong forum.....
road race has a FMIC turbo and turbo for the lancer. RIPP has a Supercharger system, or you could build your own talk to hobie
Old Feb 4, 2004 | 11:57 PM
ssjadam03's Avatar
wow if he's not talking about the ralliart that's the most newbie post I've read in awhile...but if it's not the ralliart then yeah talk to rob at roadrace for all your turbo needs
Old Feb 5, 2004 | 10:08 AM
TURBO TECH P.R.'s Avatar
<Post Removed. Posting in all CAPS is not allowed.>
Old Feb 5, 2004 | 10:35 AM
OZevoVII's Avatar
Re: turbo in lancer?
what about a TD04? and do not post in all caps.
Old Feb 5, 2004 | 12:47 PM
mitsumichael7's Avatar
The TD04 is a little small, the TD05 is the factory Eclipse 1gen Turbo. Do a search and you will get good results on the turbo kits for this series of cars. Good power numbers at modest boost levels.
SuckaFree
Aug 25, 2005 09:54 AM
4x4jeep
Sep 21, 2004 02:27 PM
KKSlider
Lancer Engine Tech
Feb 3, 2004 04:25 PM
rsur5
29
Jan 29, 2004 03:26 PM
saucemaster
37
Aug 4, 2002 02:59 AM
