2 Quick Q's (small intercooler & first buys)
Old Jun 7, 2013 | 10:08 AM
=AA=ExisT[TFCC]'s Avatar
I searched and thought about these and couldn't find much in the way of specific answers so:
1. If I use a smaller intercooler (think wider, shorter top to bottom) could the crash bar stay in? I'm sure it would require custom piping but I'm going to need that anyways to get around the clutch slave issue on my MT 05.
2. What should I buy first? I was thinking the tactronix cable + evoscan, so I can flash the ecu and start learning how to tune while I gather parts. Then maybe start installing gauges and getting the custom manifold made?
I'll start a build thread as soon as I start getting parts in.
Thanks
Old Jun 7, 2013 | 10:18 AM
One other thing: is it possible to tune on an iPad? I have an ancient windows laptop but the iPad would be a whole lot nicer...
Old Jun 7, 2013 | 11:40 AM
Pps: I just got a second job. This project is a GO!!!! :-D
Old Jun 7, 2013 | 01:16 PM
RoadSpike's Avatar
no definitely not a mac sure but not an ipad.
Old Jun 7, 2013 | 02:26 PM
Fair enough. I'm gonna have to do some work on my laptop then. :-/ thanks for the input
Old Jun 7, 2013 | 04:24 PM
Grind3r's Avatar
All depends on what your looking to spend on the Intercooler.....If ya look around, you could get lucky and score a really high-Q one. I ran a cheap one for about 6 months cause it was free, but shopped around and landed an Extreme Turbo Systems 2G Street Intercooler for $150...Fits perfect without any modding of the crashbar....
Since it sounds like your gonna piece the kit together, picking up the cable and getting the boost and wideband in would be a great start...That way your able to get in and see how the maps all look and prepare your for tuning once its boosted...Gauges being already in there will also help you get used to how it runs stock...and seeing how the wideband responds.....After that...well, its all down hill....lol...buy as you find the parts. The rest you'll be able to learn from reading all our threads Good Luck...Keep us updated with picks
Old Jun 7, 2013 | 06:35 PM
Thanks Grind3r, that is exactly the type of intercooler I had in mind!
Ok, excellent, I have a plan! Get the custom manifold project started, get the tactronix cable, evoscan, and all my gauges!
I'm so flipping stoked about finally being able to do this! ;-D
Old Jun 8, 2013 | 01:54 PM
Ok new question:
I'm about to buy a tactrix cable from www.evoscan.com and there is an option for evo4-9 AYC/ACD reflash support (no pin9). Do I need to check that option or no?
I'm assuming no since i havent seen anyone mention it in any threads...
thanks
Old Jun 8, 2013 | 06:41 PM
03lances's Avatar
Ok new question:
thanks
Lancer does not have active yaw control or an active center differential so I would say no .
Old Jun 8, 2013 | 07:03 PM
Yeah beatifulpunk said something to the same effect.
thanks
Old Jun 9, 2013 | 12:07 PM
eusgen's Avatar
Is this the right cable?
http://www.evoscan.com/evoscan-gps-o...flashing-cable
Old Jun 9, 2013 | 04:19 PM
I got the 1.3U. It seems they're essentially the exact same thing except for something about EcuFlash licensing that I'm not sure I understand. Lol
Old Jun 9, 2013 | 05:09 PM
eusgen's Avatar
Ok and we want the one without pin 9 correct?
I am having a hard time figuring out that "licensing" difference too lol
Old Jun 9, 2013 | 05:27 PM
From what I understand, pin9 will do nothing on our cars, so you can have it removed if you want. I don't *think* having it would cause a problem with the connection. I just left that option blank and added a note to my order to the effect of "I have a 2005 oz lancer m/t please send the appropriate option with regards to pin9, thanks).
In hindsight I'd probably just click the option to take it off, but I put the order in before I knew all this.
Old Jun 9, 2013 | 07:41 PM
RoadSpike's Avatar
Ecuflash licensing is pretty simple. If the cable is not licensed to ecuflash it will NOT work with current versions / non hacked ecuflash. It will however work with evoscan.
JeremyP
Mar 25, 2016 01:22 PM
JaMRxHanzoxOZ
Nov 10, 2014 12:03 AM
Demon_ni2
698
Aug 11, 2013 06:25 PM
bigmatt33
Cobb AccessPORT
19
May 1, 2013 08:02 AM
rick1024
27
Apr 8, 2013 10:18 AM
