beastly 2.4 build
Old Aug 3, 2016 | 11:42 AM
  #121
spdracr83's Avatar
yes pretty much, first head i used to swap over last summer on a stock block came up to 45cc and i gave me a compression of 8.5:1 with stock pistons.
when i ripped the motor out of the car and decided to rebuild it due to wiped out main bearings. we found out out that my valve guides were all cracked and i didnt wanna replace them so i gave my spare sonata head to the machine shop and i asked him to cc it for me to make sure it was the same volume. he confirmed that it was 45cc as well. so i used that to accomplish my desired compression of 9.5:1
a side note. i noticed that you installed ARP main studs without getting the block line bored. i was told that is a big no no when u r changing hardware and that u must get it line bored.
Old Aug 3, 2016 | 03:41 PM
  #122
crf inc.'s Avatar
Gottcha.
And your right I didn't line bore it. I line honed it. �� The entire block has been fully machined. Top to bottom. Some things I may have forgot to list but that doesn't mean I haven't done it.
Old Aug 11, 2016 | 10:30 AM
  #123
kjsperformace's Avatar
Will a420a fit in a lancer
Old Aug 11, 2016 | 09:11 PM
  #124
CrAnSwIcK's Avatar
probably, but why?
Old Aug 12, 2016 | 04:34 AM
  #125
Bc I find more performance parts for a 420a then a 4g64 engine
Old Aug 12, 2016 | 08:38 PM
  #126
CrAnSwIcK's Avatar
you realize a 4G64 is essentially a 4G63 with a larger bore, right? I find it hard to believe you're having any trouble getting parts for a 4G64, as MANY Evo owners use 4G64 block to build stokers...the only conceivable thing I can think of why anyone would want to swap to a 420A, without already being stuck with a DSM that has one, is that because the engine was used in a DSM, there are plenty of bolt ons and turbo kits available for them, so people with 420A's could pretend they had a legitimate eclipse/talon, when really, you could just 4G63 swap it, and it would be better from the get go...6 and 7 bolt 4G63 engines bone stock bottom ends can make 450-500hp, no problem...try that in a 420A. would consider a straight up 4G63 swap long before I would even think of a 420A. You could even put a 4G63 head on your 4G64 and, watch all of your problems go away, mind you the 4G64 bottom end is not any stringer than a 420A.
what parts are you looking for?
Old Aug 12, 2016 | 09:55 PM
  #127
02modlanceroz's Avatar
^^^ 100% correct lol
Old Aug 13, 2016 | 05:25 AM
  #128
Will the camshaft a in a 4g63 fit the 4g64 engine then
Old Aug 13, 2016 | 05:26 AM
  #129
I'm Gona use a 2000-2002 4g64 block and was woundering if 4g63 parts are the same and if the camshaft from 4g63 will fit in a 4g64 engine
Old Aug 13, 2016 | 08:42 AM
  #130
Evo head will bolt right to it.
Old Aug 13, 2016 | 08:43 AM
  #131
Ok will the evo camshaft fit on the 4g64 engine
Old Aug 13, 2016 | 02:07 PM
  #132
crf inc.'s Avatar
Simply put, NO! Evo cams will not fit non a 4g64 head. They're completely different heads. The g64 is a single cam head while the 4g63 is a dohc. You could run either an Evo 8 head or a g5js dohc head from an Hyundai Sonata and then you could run Evo cams.
Old Aug 13, 2016 | 09:43 PM
  #133
doncarbone's Avatar
I was under this assumption as well and was going to pretty much say what you did, however I discovered there is a DOHC 4G64, although I imagine it's fairly hard to come by, and the chances of the EVO camshafts fitting are still a crap shoot.
I would strongly recommend sticking with the 4G64 for the reasons mentioned here. The 4G64 bottom end can be built just as the 4G63 can; you essentially have access to all the aftermarket support the EVO has, and if you're willing to build the rotating assembly up, you might as well source an EVO 8 head and benefit from improved flow and forced induction potential.
Old Aug 14, 2016 | 06:38 AM
  #134
I'm Gona use evo heads as long as I can use evo camshaft on a 4g64
Old Aug 14, 2016 | 10:43 AM
  #135
doncarbone's Avatar
