Dynoed my auto intercooled lancer v2.0
Old Mar 18, 2004 | 04:17 PM
IILANCERII02's Avatar
good job vince - i am very jealous of you and cant wait to get my auto turboed
as for the other people starting to flame on him or make stupid remarks , please just dont and dont come to this thread. No need to harass him about his awesome accomplishments!
Old Mar 18, 2004 | 04:21 PM
pgmike's Avatar
hey vince i just talked to andrew on the phone and he said if i wanted to get an IC i would have to reverse something in the turbo. could you clear this up for me, i didnt quite understand what he meant bc i am a turbo n00b?
Old Mar 18, 2004 | 04:22 PM
Evo Spec VIII's Avatar
o yea quite awsome i might add. have u ever heard of another lancer oz being able to run15's ? sweet jesus thats fast for an oz
Old Mar 18, 2004 | 04:29 PM
bahamut's Avatar
Questioning something or someone does not constitute flaming.
Flaming = "that xyz product is the worse that I have ever seen . . .." Basically, nothing to backup the naysayer's claim.
As for those #'s, they look close to 7-8 psi, not 5 psi.
A mirage G93 w/ a T3 60 @13 psi can crank out about 238 whp w/o tuning on forged parts.
Old Mar 18, 2004 | 04:41 PM
Guru_Del's Avatar
pgmike,
you have to get the compresser housing turned 190 degrees, look at where the pipe goes on a non-ic turbo, it is u shapped and goes straight from the turbo to the throttle body, now look at the one in my profile, you will notice it goes the other way, it goes down to the intercooler.
Evo Spec, I am glad you are so impressed with my car, maybe you should have gotten an OZ instead
Old Mar 18, 2004 | 04:44 PM
i woulda but in the end i probably would have drove it off a cliff because i can;t drive something that takes a lifetime and a half to get to 60. BUT, now urs doesn't. how much further are u takin it with this setup? (est. whp when ur done)
Old Mar 18, 2004 | 04:49 PM
pgmike's Avatar
vince how much would it cost for the ic piping? and how much to to get the turbo turned around rewelded?
or do i even have to get it turned around? could i just get some local guiy to do piping for me that makes it so i dont have to turn it around? is there even enough room to do that?
Old Mar 18, 2004 | 04:53 PM
Guru_Del's Avatar
I would call RRM for piping prices, a machine shop can cut and weld for you.
Evo, I am not sure, 200whp was my first goal but since I am so close I might move that goal out to 220 whp. I guess running 7 psi with a header and exhaust will put me close so probably nothing too crazy.
Old Mar 18, 2004 | 05:02 PM
pgmike's Avatar
i thot autos couldnt run more than 6psi safely
Old Mar 18, 2004 | 05:15 PM
Guru_Del's Avatar
pgmike,
well frankly no one knows so we will see. I have an auto tranny fluid cooler so that might help me aswell as some other tricks up my sleeve.
Since this is my daily driver I dont want to go all crazy on it so this looks to be almost the end of the road for performance, unless i get the bug and get internals (rods and pistons) then i will go for more fuel and 10 psi hahah, but that high I am sure the tranny will have to be rebuilt.
Old Mar 18, 2004 | 05:25 PM
pgmike's Avatar
the way i am limiting myself is by not sayinga certain hp mark but a set amount of money spent mark. with that much tho i am hoping to rach around 240whp.
Old Mar 18, 2004 | 06:22 PM
mcpcola's Avatar
Guys **** No one knows for sure what HP he has because the car was dyno'd wrong when he gets it redone he can use the right gear and then we will know for sure.
Old Mar 18, 2004 | 07:36 PM
Hey Vince - did u install the turbo and everything yourself... and if so... was it hard or like moderate? If you have time/want too could you kind of do a write up in another thread, that would be much apreciated, b/c im looking at either turbo or supercharger and wanna know what im up for.
thanks.
Old Mar 18, 2004 | 07:53 PM
TURBOit's Avatar
a machine shop will not charge much to cut the tube on the turbo and reweld it, just make sure you get an aluminum welder, its not exactly like welding reg steel, i too am a bit skeptical as to the numbers, i have vinces setup + all the mods you can do, and i just do not feel it is putting out those kinds of numbers, i think it has something to do with the FWD system and no LSD, :\ well, eventually i will dyno too, and so will vince, and that will give us 2 comparison charts, i still need to make sure i am not getting blow by
Old Mar 18, 2004 | 09:17 PM
Guru_Del's Avatar
well all i know is my car feels better than most cars i have driven in. Rob from RRM was supprised when he drove it.
As for the install, I had RRM do it however I was there and helped. The only dificult thing was tapping the oil pan.
