Stage 2 Turbo
Old Feb 22, 2005 | 08:34 PM
  #106
Boeturbolancer's Avatar
106 degree day... full pull in 3rd to redline... 11psi on 91 pump gas... and to top it off she bounced on the rev limiter. Need i say more? Stage2 was designed for 9psi and i was pushing it past that... living on the edge was my thing and that day it caught up with me.
I will say bouncing on the rev limiter in any boosted/NA/nitrious car is bad for it. Though you may get away with it for a long time it is detromental in many ways. Especially if you car was never designed for boost... the ecu doesn't pull timing/cut spark instead it does nothing with timing and cuts fuel. That means there is still spark without enough fuel which leads to detonation. In the end she cried... i kicked her... she cried some more... i kicked her again... then she got knocked out so i had to appologise and move on. Wierd how it worked out that way.
Old Feb 23, 2005 | 07:13 AM
  #107
Phantom0's Avatar
well Boe if i ever get a turbo maybe you could help me out with it. my bro can put it in, but you know more than he does. about turbo anyway. i am only in the 951!
Old Feb 23, 2005 | 10:20 AM
  #108
Guru_Del's Avatar
nah that ***** crazy!!!!!!!! hahahah j/k boe
I ran stage 2 on my lancer for awhile and beat the hell out of it.
Boe always monkeyed with stuff so i am sure he wasnt running just what rrm had hahah.
I know i ran just rrm and made great power and was super reliable.
Old Feb 23, 2005 | 11:52 AM
  #109
phantom0 i'm 951 (hemet)
Old Feb 23, 2005 | 10:40 PM
  #110
ROCK's Avatar
951......same as 909.
ROAD/RACE
Old Feb 23, 2005 | 10:44 PM
  #111
Z_Lancer_Man's Avatar
Sorry, but what does 951.... 909 etc mean?
Old Feb 24, 2005 | 05:29 AM
  #112
KillahB's Avatar
Area codes, I presume.
Old Feb 24, 2005 | 07:06 AM
  #113
Phantom0's Avatar
we live in the Inland Empire. some a-hole got a bright idea to seperate the center from the outside. so Riverside Metro is now 951. and outlaying Ontario metro is 909. we all used to be 909. boe you gonna attend this meet sclc is havin?
Old Feb 24, 2005 | 06:52 PM
  #114
not for a bit... have some things to get on the car first so i can pimp.
Old Feb 24, 2005 | 06:58 PM
  #115
Hotshot940's Avatar
boe how long did you run daily at 11 psi on 91 before the redline incident?
Old Feb 24, 2005 | 08:32 PM
  #116
4-5 months at that pressure... before that i was running 9/10 for about 8 months on stage 2 tune that RRM sells.
Old Feb 24, 2005 | 09:09 PM
  #117
Hotshot940's Avatar
i plan on running rrm stage 2, 9-11 psi, ohio summers (70-100 degreees), 94 octane, does that sound ok?
Old Feb 24, 2005 | 09:59 PM
  #118
Stick at 9psi and you'll be fine... after that you are riding the edge and i don't recommend it. I didn't mind blowing the motor to much as i've done it so much before i can change pistons in my sleep.
Trust me though... stick with the boost the kit offers and be happy as beyond that you are messing with dangerious territories.
On race gas i'd say you could do 11 no problem. After that you'd be pushing it. Good luck.
Old Feb 24, 2005 | 10:16 PM
  #119
Hotshot940's Avatar
Considering you are the voice of reason, I will listen to you. Thanks for the information Boe.
Old Feb 24, 2005 | 10:30 PM
  #120
Voice of reason... more like voice of experience from alot of mistakes
